I retrieved my abs code on my 95 bronco 5.0L. It is code 17 which is reference voltage. Any one know what direction I should be going next(other than a service center, not ready yet) thanks.
That code means the voltage supplied to the abs module has
dropped below specs. You might suspect the alternator and regulator. But first i would ck fuses and ck for power at the module (abs). It would be helpful if you have a wire diagram.
