Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
GM axes hybrid pickups until two-mode system debuts in 2008
Old 04-28-2007, 08:23 PM
Red Star's Avatar
Red Star
Red Star is offline
http://www.autoweek.com/apps/pbcs.dl...024/LATESTNEWS
Old 04-30-2007, 04:30 AM
BigF350's Avatar
BigF350
BigF350 is offline
And a good move in my opinion...
I would be even holding off on the "two-mode" system if results out of Scuderi's developmental twin piston engine are anything to go by too...
Old 04-30-2007, 10:44 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
This was all I found about twin piston engines-
http://www.freepatentauction.com/patent?nb=1234
I'm assuming the one you're talking about is a bit better designed?
Old 04-30-2007, 03:20 PM
SMIGGS's Avatar
SMIGGS
SMIGGS is offline
The Hemi's are also going to the "two mode" system in 08. Anyone hear of plans for something like this for the Ford Modular engines?
Old 04-30-2007, 06:25 PM
BigF350's Avatar
BigF350
BigF350 is offline
No - that design is similar to the old Junkers Jumo aero diesels.
This involves having two cylinders connected to a common crank (like a V-twin).
The first piston does the induction and compression stroke. The compressed air then goes to a accumulator.
The main advantage to it is that it is so much cheaper to build than a "conventional hybrid".
You also have the advantages of designing the pistons specifically for thier tasks too (power stroke, or compression).
Being able to use the "miller cycle".
Through engine braking you can store the "energy" in the accumulator in the form of compressed air.
You get a much more efficient engine, as the compressed air can be cooled prior to combustion.
Engines that can easily be supercharged - by making a compression cylinder that has a larger bore than the combustion cylinder.
I can't find any websites on it.... will try and scan a schematic when I go home.
Old 05-02-2007, 12:30 AM
Frankenbiker's Avatar
Frankenbiker
Frankenbiker is offline
Old 05-02-2007, 02:43 AM
BigF350's Avatar
BigF350
BigF350 is offline
tanks
