Fuel Filter Location? - 73 Ranchero
Old 04-30-2007, 03:38 PM
Defcon888's Avatar
Defcon888
Defcon888 is offline
Does anyone know where the fuel filter is on the 73 Ranchero with the 400 engine? Thanks. I'm having trouble finding it because its not easily visible! Aargh =)=(
Old 04-30-2007, 04:24 PM
fl1a's Avatar
fl1a
fl1a is offline
Look where the fuel line enters the carburetor. Some have one that acts as a nipple
for the rubber fuel line. others have one that is inside the carburetor where the line
connects to it. The first kind threads into the carburetor. It is around an inch in
diameter.
Old 04-30-2007, 04:30 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
you either have the fuel filter at the base of the fuel pump or the screw in type that is mounted on the front of the carb.
Old 04-30-2007, 04:39 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Screws into the carburetor, front. it does as member fl1a says, acts as a nipple for the fuel hose.
D3AZ-9155-C .. Fuel Filter (Motorcraft FG-14)
73 fourxfour
03-03-2015 01:13 AM
nekomejia
09-18-2014 10:22 AM
dmantt
11-22-2005 08:29 PM
john73ranchero
05-02-2004 06:03 PM
Boaz32
09-08-2002 02:58 AM
Quick Reply: Fuel Filter Location? - 73 Ranchero
