gearbox change
gearbox change
Yes im putting nos gear box and shaft in my 54 ford truck. My question is can the gearbox and shaft be pulled if i get front of truck raised enough and slide the new gearbox and shaft from bottom of truckdown through the tube or will i need to pull through cab. I was told it was possile to pull this way and not have to pull the whole column throgh cab. thanks
