gearbox change
Old 04-28-2007, 09:48 PM
saauvenshine's Avatar
saauvenshine
saauvenshine is offline
gearbox change
Yes im putting nos gear box and shaft in my 54 ford truck. My question is can the gearbox and shaft be pulled if i get front of truck raised enough and slide the new gearbox and shaft from bottom of truckdown through the tube or will i need to pull through cab. I was told it was possile to pull this way and not have to pull the whole column throgh cab. thanks
Old 04-28-2007, 10:00 PM
51dueller's Avatar
51dueller
51dueller is offline
You could but it is easier to pull it through the cab as you don't have to remove the wheel. You still have to remove the same parts to pull it out the bottom as the top.
