Freight harbor Winch review?
I am considering buying this 8,000 lb winch from someone for $250.
http://www.harborfreight.com/cpi/cta...emnumber=40764
He said it was used once, and is mounted on a 2" hitch. (I have a hitch recevier in the front)
I dont do any hardcore mudding, but I would like it to do smaller things, like pulling out jeeps!
-josh
-josh
Ever give a thought to why it was only used once?
I have bought cheap winches before and I found an excuse to always use them. I would question the "once" unless the vehicle is a trailer queen.
There is a reason why there is a $300 price difference between that and a 9k Warn.
Before you buy it, have it hooked up and pull a vehicle up an incline, on pavement would be fine. It should pull the other vehicle even if the wheels are locked. If it can't, the winch is smoked.
A few ****** blocks can make a cheap winch almost good!
I'd also check out 4wheelparts too, they usually run some good deals on their winches...
http://www.4wheelparts.com/PPT2919T5141.aspx
Originally Posted by Josh88Ford
i would like to for pulling boats up from hunting, and just small things like that. I know if I get it, i will have friends calling me and bothering me to pull them out.
Would this pull me out if i were stuck(not buried)
Yes, it would, if you weren't buried, but how many times would it be able to do that? If you ever used it to pull you out of mud that was up to your axles, you would eventually kill it, maybe the first time, maybe a few times down the road.
However, for street usage, I don't think it would be that bad of a deal.
dave2
21
03-19-2008 02:29 PM
