93 ford 4.0 water leak
I have a 93 ford explorer water started leaking from the back of the motor on the top.can anyone tell me where this water may be coming from and if it is a simple problem to fix or does it need to go to the shop for repair.it never ran hot it just started leaking when i pulled into the drive.
I'm trying to remember the backside of my engine that I just reinstalled on my Ranger(Same engine as my 92 Ex...should be same as yours). It seems like there's a freeze plug on the back end of each head and there's a couple of freeze plugs on the rear of the block. There's no other external antifreeze lines, and the heater hoses are visible off to the side. Other than the freeze plugs, there shouldn't be anything else that could be the source of your leak. Hopefully it's a head plug. You'll need to pull the engine if it's the block plug. I suppose there's the possiblity of a head gasket leaking too. Can you get a mechanics mirror back there to see things better?
If it is leaking on the passenger side, my bet would be the lower intake manifold gasket.
There is a water passage at the rear of the block that is prone to gasket leakage, have seen them pour out at a gallon in a couple of min. About a 4-5hr job if you do it.
You will need a lower, upper, tappet cover gasket, some hi temp RTV(O2 safe) and tourque wrenches(in/lb and ft/lb). Torx sockets are usfull as well.
Be meticulious when cleaning the old gasket and when setting the new.
Good luck
Good luck
Supercouper
10-05-2009 10:48 PM
mtl93ranger
01-29-2008 09:32 PM
93bigbronco
1978 - 1996 Big Bronco
12-17-2001 11:43 PM
