Installed the LIPD Cross Over Fuel Line Mod Yesterday and......
overall it went OK. I had the use of a lift and the easiest part was removing the exhaust bolts, believe it or not. The Y pipe flex joints allowed just enough movement but was enough to get the plugs out. I could not get a 3/8 drive 6mm allen in the plugs even with the Y pipe exhaust ends moved. On the driver side I used a short 6mm regular allen wrench and used a long boxed end wrench to get leverage to break the plug free. On the passenger side, because of the downpipe, I had to use the same allen wrench but put a 10mm 3/8 drive deep socket on a 3/8 universal turned 90° with an 18" 3/8 extension attached. One wrap with a hammer on the extension and the passenger side plug was free. Make sure the allen wrench is FULLY inserted in the plug. Once they were free, they could be easily removed with fingers. Now here comes the tricky part and in my case the most time consuming. I installed the line on the drivers side first and this is fairly easy to do because the line is hanging straight down. On the passenger side it took me an hour because you need to bend the line and insert the bolt at the same time with almost no room. The sealing washer that seals the fitting to the block kept falling off (about 10 times) so I put a very, very, very small amount of fast curing RTV on the seal and placed it on the fitting. Once it hardened, I could now try to insert the bolt. No luck. I needed another hand to push the line forward to straighten the fitting against the block. Finally, my cousin showed up and he advanced the line while I aligned and inserted the bolt with one hand. That took 5 minutes. I did not have to remove any EGR cooler line clamp as per the directions. Turned the key on and no leaks. Put the exhaust bolts back in and started her up. I had the initial air in the injectors problem but cleared right up.
Initial impressions - it seems to start quicker when hot. Turbo lag seems to be less or I should say not as often and for what reason I don't know. I did not notice a reduction in noise as others have stated but I'm glad that damn thing is in. Will let you know if any other benefits are noticed, like MPG increase. Now I'm going to take my 60 year old sore gimblit a** and put it in the hot tub.
DSMMH
DSMMH
Originally Posted by pstrang
Thanks for the write up.
That's interesting that you didn't need to loosen the EGR cooler clamp. You unbolted the passenger side uppipe. But it shouldn't move much at the flex joint if the EGR clamp is still tight.
Where is the EGR cooler clamp located? I did not see any clamp attached to the passenger side up pipe.
The driver side up pipe moved easier and further away from the block then the passenger side because the flex joint is higher. After removing the passenger side up pipe exhaust bolts, I took a large screwdriver and CAREFULLY moved the pipe about 3/4" away from the block. That actually gave me a little more room then on the driver side. If I had to do another one, I could cut my install time in about half provided the exhaust bolts came out as easy as mine did. But I'm not doing another one.
OBTW - I would not advise anyone to do this mod unless you have access to a lift.
DSMMH
Originally Posted by bansheemike
My kit is waiting for me at home (I'm in Hawaii right now). Do you really recommend a lift or does it just make it alot easier? I might return mine if it's that much work.
A lift is not mandatory but, IMO, sure makes the job a lot easier. If you are young maybe 4 jack stands will do the job. Maybe some of the guys who have installed them without a lift could give you some better insight.
DSMMH
I'm also suprised you got the uppipe off the exhaust manifold to move it. It's beveled and fits inside the uppipe. You have to lift it a bit to seperate that junction.
Perhaps the flex joint is more flexible than I thought. Or maybe you have an aftermarket uppipe without the EGR cooler connection? Have you owned the truck since new?
the Install is a Pita. there are some instructions and tip on the TDG. It's worth it but it a tight place to be working the passenger side is a breeze compared to the drivers side. Just pull out th einner fenderliner and you can seee what you are working on. the driver side you need a short 6 mm allen wrench and a n extendsion handcasue they are in there tight. once it is loose your home free just wedge back the lower part of the up pipe with a block of wood the you can get in there to work.
