Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-12-2007, 09:12 AM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Garage is empty, add now
Gun-Driver is starting off with a positive reputation.
Question
Fabman,
I obtained a vacuum pump and a tank to recover to. I plan on pulling the vacuum from my modified appleseed through the condenser mounted to the reactor than into the recovery tank. I have two more questions.
What temp should the bio be at when I pull the vacuum?
What would happen if I left the glycerol in the reactor with the bio (instead of setteling and seperating the two into different containers). Can you also recover the methanol from both at the same time. Either before they settle and seperate or after they settle and seperate then pull the vacuum?
  #2 (permalink)
Old 04-12-2007, 10:50 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Originally Posted by Gun-Driver
Fabman,
STOP! Back away from your processor ,now that I got your attention..............If you remove the Methanol from the combination it will revert back to ............OIL! Actually not oil at all, the bonds were cut, now it's just goo................
When I was using vacuum I had the temp at 100 deg F.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 04-12-2007, 11:15 AM
Gun-Driver's Avatar
I figured there was a good reason. Thanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
