Question
Old Apr 12, 2007 | 09:12 AM
Gun-Driver's Avatar
Gun-Driver
Question
Fabman,
I obtained a vacuum pump and a tank to recover to. I plan on pulling the vacuum from my modified appleseed through the condenser mounted to the reactor than into the recovery tank. I have two more questions.
What temp should the bio be at when I pull the vacuum?
What would happen if I left the glycerol in the reactor with the bio (instead of setteling and seperating the two into different containers). Can you also recover the methanol from both at the same time. Either before they settle and seperate or after they settle and seperate then pull the vacuum?
Old Apr 12, 2007 | 10:50 AM
fabmandelux's Avatar
fabmandelux
Originally Posted by Gun-Driver
Fabman,
STOP! Back away from your processor ,now that I got your attention..............If you remove the Methanol from the combination it will revert back to ............OIL! Actually not oil at all, the bonds were cut, now it's just goo................
When I was using vacuum I had the temp at 100 deg F.
Old Apr 12, 2007 | 11:15 AM
Gun-Driver's Avatar
Gun-Driver
I figured there was a good reason. Thanks
CheaperJeeper
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 29, 2009 03:53 PM
Rushmore X
Nov 28, 2008 04:59 PM
ckal704
Jul 17, 2008 01:36 AM
AndysFords
Feb 2, 2007 11:28 AM
fabmandelux
37
Apr 4, 2006 06:52 PM
