V8 gasser outlifts V8 diesel
I currently have a 2.5 inch leveling kit on my 2000 F250. I have a relative giving up his rear lift blocks from his F350. My thought was to swap out the blocks and then replace my add-a-leaf front leveling set-up with a 2.5 inch leaf pack type leveling kit. The diesel leveling kit always has a different part # than the gas. Is it because the springs are stiffer on the diesel due to the extra weight? If so, it would stand to reason that if I ordered the spring kit for the diesel and installed it on my gasser I would probably have more than a 2.5 inch lift. I only want a couple more inches added and $300 sounds a lot better than $800 for the 4 inch lift. Any comments?
yeah, the springs are stiffer, hence the different part number... the main drawback to running springs for a diesel on a gasser is that the ride will suffer big time... it won't ride like a truck (stiff), it's gonna ride like a tank (spine-shattering stiff)... I think the diesel is something like 300lbs heavier than the V10, I think... too lazy to look... unless I'm not understanding you... is this for the front or rear? everything I said applies to the front... not so sure about the rear...
Joey
Joey
2006lariat
1999 to 2016 Super Duty
03-12-2013 02:10 PM
SuperDutyScaler
08-16-2010 12:50 PM
