Leaf Springs and bushing "OH MY"
I removed my stock leaf springs and brackets because I was informed I would not be happy with the ride and was told by that it would not be able to withstand 500 HP.
<O</O
My questions is considering cost efficiency and performance would I be better off trying to track down a pair of old leaf springs and brackets from a junk yard if so what year and model should I be looking for?
OR
Is new the way to go?
OR
<O</O
Should I go with a rear suspension kit to convert it to a coil over suspension with a ladder bar/4 link set-up?
<O</O
Speedway motors has complete kits from $325 to $534 not sure of the quality but the price seems right…
Any other suggestions on kits you may have used and where to purchase???
<O</O<O</O
Also I would like to replace the OG wood body mounts with a rubber bushing style mount. Any suggestions on where to locate or find such a thing?
<O</O
OR
OR
<O</O
<O</O
<O</O<O</O
I can lend some experience here...
In my '57 other-brand, I ran a mild '70 LS5 BBC...probably 425 HP-550ft/lbs torque...all through the original '57 C-brand springs and hangers, only addition was coil over shocks. I did run a TH400 with only 2500 stall...but it held up very well to the abuse I put it through.
That said, with the easily available 4-bar setups you can now get and tune it the way you want, I'd do that if I were replacing the rear suspension because it was worn/etc...but if on a budget, I'd stuff a 9nich under with ladder bars and call it a day.
Flintknapper
17
02-18-2015 08:00 PM
DuluthGuy
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
28
03-29-2006 10:25 PM
