[updated:LAST EDITED ON 05-Feb-02 AT 07:51 AM (EST)]Does anybody know if it is possible for brakes to be engaging too fast when approaching fully engaged? Whenever it is rainy or snowy I always can skid to a stop way to easily. I haven't had the time to do any experimenting in a parking lot to see if I'm just having a heavy foot. :P
[updated:LAST EDITED ON 05-Feb-02 AT 09:35 AM (EST)]Its not hard to have them lock up on snow. Now if they are locking up in rain, better check your pads and shoes, also check fuse that control ABS.Also if your ABS is working, you should feel pulsating in the pedal.
check for wear and you may need to bleed your braking system. Sounds like you're not getting enough brake till you really get on them. So I would check the things I've talked about hear.
