Driver Front Oil Galley Plug Location
Can someone tell me where the oil galley plug is on the driver's side front of the head is? I have a '97 F350 4x4 PSD. I've been told by two different shops that that's where my oil leak is coming from, but I can't figure out where it is and/or how I would get to it. Part of the problem is the AC compressor in the way, but I can't believe I have to remove it just to see the plug is. By the way, just picked up a couple of these plugs from 1stfordparts.com for $4.67/apiece. Seems cheap compared to other dealers.
Thanks in advance!
George
Thanks in advance!
George
on
there are also large end plugs ont he front side of the head under the accessory drive brackets (the brackets the a/c compressor and vacum pump, PS pump) they are larger with a 1/2 inch square drive hole. I believe they are only sold in as a complete plug now.
Oil Rail End Plugs (large plugs at each end of heads; incl. O-rings)
(Navistar) 1827535-C91
So I'm attempting this job today and I'm stuck trying to remove the bracket from the motor. Got the compressor off no problem, but I'm trying to pull the bracket off and must not be finding all the bolts that attach the thing to the engine. So far I've gotten 3 13mm bolts out but the bracket won't budge. The other bolts are bigger and look like they simply hold the P/S pump to the bracket. Does anyone know how many bolts attach the bracket to the motor? I can't believe I'm having so much trouble finding them.
Thanks!
Thanks!
on
I went out and looked at my truck and could only see two bolts (I didn't get right in there with a light or anything) but I am quite sure three sounds right. I have never had that side off. I did find a bracket on ebay but it was for a 99 but it looked to have 4 bolts that mounted it. it might have locating dowels that are stuck?
Thanks, Tim. There was a 4th one hiding. Got it out and replaced the galley plug in about 5 min. Now I'm trying to put a new serp. belt on and I can not for the life of me get it to go on. Is it supposed to be this hard? I've got the auto-tensioner pushed as far as I can go and still can't get the belt looped over the alt. pulley. It's a Motorcraft belt, so I'm pretty sure it's the right one.
Thanks!
Thanks!
Originally Posted by grantorino
Well, I thought I was all done. Went to start the truck tonight after it had sat a couple days and it took about 2 tries 10 seconds each to get it going. Does this mean my newly installed galley plug is leaking oil pressure? Damn! I really don't want to do the job all over again
