1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
ABS sensor problem on 2000 Expedition
Old 04-03-2007, 10:24 AM
davebar's Avatar
davebar
davebar is offline
I just replaced the lower ball joints and musy have twisted something in the ABS set up. I am not sure what is wrong yet and I am puting it on the scanner tonight to get the code to figure out where the problem is. I am sure with my luck, it needs a new hub. It appears the sensor is part of the wheel hub.
My questions is: I cant get the part for a few days cuz of shipping and none of the local parts shops have it either. I am driving this truck from Cleveland to Orlando and I need to leave this Thursday night. How dangerous is it to drive with the ABS light on, assuming it is a sensor? I have brakes and they seem to be fine, I assume the anti-lock may not work. Which is a concern driving in the mountains of WV.
Please advise....I will post agian after I do the diag test and let you know what the codes say.
Dave
Old 05-23-2007, 12:33 PM
shamrock1's Avatar
shamrock1
shamrock1 is offline
Thumbs up
Hello to all you Ford addicts. I've been one for more years than I care to admit. Now I have an electrical problem and would like some help diagnosing it. I know there are hundreds of you smarter that I when it come to electrical problems, so I will appreciate your help. My ABS light started to lite up and stay on. Plus my speedometer has started to drop down to 0 when speed drops below 25MPH. I'm wondering if this is the SSV unit on the defirental causing the problem.
Old 05-23-2007, 12:58 PM
shamrock1's Avatar
shamrock1
ABS Light Failure
Dave, My ABS light has been staying on for over a week. It would be my opinion the driving with the ABS light on doesn't have any dire problems unless you would get into a position (near Accident) and they would become a must. I drive my truck every day. There seems to be many different things that could cause the ABS to light up.
Shamrock1
Old 05-28-2007, 05:32 PM
wchain's Avatar
wchain
wchain is offline
No effect with the ABS light on. Sounds like you may have broken the sensor wire. Let us know what you find.
Old 05-28-2007, 07:07 PM
davisenvy's Avatar
davisenvy
davisenvy is offline
Just get the part from the Ford Dealer. It's only $25. It isn't dangerous to drive with the sensor out as far as damage to your truck, but ABS is a safety feature.
Old 05-29-2007, 12:33 AM
MazdaRangerGuy's Avatar
MazdaRangerGuy
MazdaRangerGuy is offline
Yes this shouldn't affect your normal brakes at all.. just keep in mind your ABS will not kick in should a wheel lock up on you during braking.
shadester
12-05-2012 05:38 PM
beamundson
1997 - 2003 F150
03-28-2012 04:23 PM
ChrisCarter
2004 - 2008 F150
01-26-2012 10:24 AM
GUNNERDOG
1999 to 2016 Super Duty
32
05-29-2011 06:41 AM
pwrstroketx
01-03-2009 12:30 PM
Quick Reply: ABS sensor problem on 2000 Expedition
