Fuel lines on front of block
Hello everybody, Was wondering if anybody new the fuel presure on the two steel lines on the front of the block. One looks like supply from the tank to filter the other is return from filter to the tank. Good N.Y. state salt rusted line out. Just wondering if could splice in a rubber line. Thanks David
For what it's worth.
I had the fuel lines on my 96 rot away at the point where the oem (12" or so long) flex line links between the engine and aft of the steering box. I just cut the rotted area off of the engine side, put some rubber fuel injection rated hose, and clamps in place of it. It's been that way for over a year with no problems at all. I did slip some plastic wiring loom over it to be sure it wouldn't rub against the frame or crossmember. I last inspected it a month ago, and all was still well.
JasonVoor
09-09-2014 03:19 PM
dig'umz
03-01-2013 09:20 PM
bigern6697
17
08-14-2011 05:29 PM
