any ideas for mounting front & rear bumper?
Bill - I'm working from memory here. The PO moved it in. I took it off. I'm running without a front bumper currently.
I'm not sure an F1 has as severe an overhang problem as the 53-56, but moving the bumper in when dropping the suspension had big payoffs on driveway entrances and street dips. Even then, I slapped the bumper on the ground many times. The good part is that the bumper can take it. The license frame couldn't. I replaced three of them before I quit running a front plate.
Here's a pic of the tucked bumper: https://www.ford-trucks.com/user_gal...=52331&width=0
49, on my 56 it seems that every so often I cut more off the frame horns LOL... I really like the tucked look of the bumpers. I'm currently about 1/2" away from the ends and the lower valance. I like it that way. My friend has a 50 F1 and his is about 1.5 inches. I think the F1's look better not as tight up as the 53-56. I guess it's a matter of opinion. Here's a pic of his truck.
Yes he moved it in 1 inch. His sits about 1.5 inches from the body. The bumper and truck was painted Dupont color Radiant Red. I have some more pics if you need them.
Thanks, Bill
Ed - Great idea. Shortening the stock bracket would certainly be easier than making a new one.
Bill - I took some pics and made sketches of the Hugger Brackets I have.
Side view pic: https://www.ford-trucks.com/user_gal...146725&width=0
Top view pic: https://www.ford-trucks.com/user_gal...146726&width=0
Flat pattern drawing: https://www.ford-trucks.com/user_gal...146727&width=0
Formed bracket drawing: https://www.ford-trucks.com/user_gal...146728&width=0
The location of the bracket on the frame rail is to align the bottom edge of the bracket with the bottom of the rail and push it as far forward as you can before it almost hits the spring hanger. That's how mine is on the 56. You may have to play with it some on your frame to get the right fit. But these did bolt right up to my stock bracket holes. The brackets are listed in John's F-Fun Hundreds catalog as fitting 48-60.
Good luck.
Good luck.
Randy Jack,
your links dont seem to work could you email me the photos and drawings?
mudrat025
10-25-2012 12:02 PM
Aune163rd
52
07-19-2011 03:13 AM
GreatNorthWoods
17
06-01-2005 10:44 AM
