If you are talking about code P0182, first check the wiring to the sensor. Make sure no exposed wires and good contact to the sensor. If all is good then I would say the sensor itself is bad. Not sure what the factory test is. Its on the fuel rail and has the electrical connector.
UPDATE
I got home today, and started it up, and put the OBDII reader on it, NOW I get P0171, and P0174, that flashes a couple times on there, then I get the other codes (above), it went through these cycles a few times, then just went away! I drove it about 10 miles, and it never came back, soooooooo, your guess is as good as mine at this point
