How do you clean a mass air flow sensor?
I am getting check engine codes PO171 and PO174 (too lean on bank 1 and bank 2) on my 1997 Expedition and have read some of the threads on what to check. One possible cause is a dirty mass air flow sensor.
Can someone tell me what to do to clean this?
Thanks in advance!
Lee G.
Cypress, TX
Thanks in advance!
Lee G.
Cypress, TX
Do NOT use Throttle Body cleaner.
Do NOT use Carb/Choke cleaner.
I wouldn't recommend touching it with anything like a Q-Tip.
Use this:
http://www.autobarn.net/maairflsecl1.html
If you spray anything on the platinum wire/plate that leaves a residue and change it's heat dissipating properties, you have just created a nice paperweight.
Use this:
qrguiles
05-04-2012 08:29 AM
