View Poll Results: Would you like a tech article on how to re-wire your factory harness to MAF?
Yes, I would
496
95.02%
No thanks
0.77%
I duno, I might...
22
4.21%
Voters: 522. You may not vote on this poll
SD to MAF Conversion - Write up?
Old 12-03-2008, 12:43 PM
KDPate's Avatar
KDPate
KDPate is offline
Getting ready to do this setup on my 88 once warmer weather arrives again. Got a complete underhood harness, Computer (X3Z code) and the matching MAF (all came out of a 93 Cobra). Also plan on changing out my camshaft (Melling MTF-5), adding 24lb injectors, and going to an Explorer style intake w/a 1/2 or 1" spacer between the upper and lower plenums. Plan on documenting everything done wth text and photos for future reference.
  #242
Old 12-03-2008, 01:37 PM
monkei's Avatar
monkei
monkei is offline
Question
Who's looking for 460 MAF conversion parts?
How much would you pay for the harness, w/e40d/maf ECU, dist, injectors/fuel rail, MAF, and ACT sensors?
  #243
Old 12-21-2008, 04:14 PM
dutchlincoln79's Avatar
dutchlincoln79
dutchlincoln79 is offline
well, i am...
Scematics would be nice, a complete harness and computer would be great...
tell me what you have, and how much it will be...
thanks.
  #244
Old 01-17-2009, 01:23 PM
ri_truck_guy's Avatar
ri_truck_guy
ri_truck_guy is offline
Bump. Did anyone ever find or write of detailed set of directions for doing this conversion?
  #245
Old 01-17-2009, 04:50 PM
3golfjack's Avatar
3golfjack
3golfjack is offline
I thinks it great having this site. The tech articles can be very useful. What you don,t need now sometimes you will need later. The more Tech info the better.
  #246
Old 01-27-2009, 05:36 PM
jarod17's Avatar
jarod17
jarod17 is offline
I have decided that if I can not get to Cali and find a 7.5L F-250 with an E40D to pull parts off of I am going to make my own harness. I have a couple of questions though.
1: I have the wiring diagram for a '96 F-250 with the 7.5L but it calls for three O2 sensors. Left, right, and rear. Does anyone know where these are located in the exhaust so that I can design my exhaust right?
2: Does anybody know what computer is used on the 7.5L maf F-250 with E40D?
  #247
Old 02-02-2009, 12:46 PM
dutchlincoln79
That would be Gold information indeed.
Can you share the wiring diagram? I'm very interested in it.
I'd like to make my own harness also.
(however: if i can order it somewhere, that would probably my first choice.. )
Thanks!!
  #248
Old 02-15-2009, 01:41 PM
dutchlincoln79
well, lets give it a kick up. Question still stands...
  #249
Old 02-15-2009, 01:52 PM
wantaford's Avatar
wantaford
wantaford is offline
Question 1: Left & Right O2 Sensors are on the inside of the elbows coming off the exhaust manifolds as it shoots to the tee and then on to the Cat. The third sensor screws into the back of the Cat as the exhaust exits the Cat.
Question 2: I would have to open up the kickpanel and pull it out to see what the number is. I have never paid attention. So when I am in there I will let you know. But I have a manual trans so the computer would be different!
Cali-Emmisions MAF trucks have no smog pump and no air tubes so you don't have to mess with that crap!
  #250
Old 02-16-2009, 02:37 AM
jarod17's Avatar
jarod17
jarod17 is offline
Sorry for the delay in responding. As soon as I get the chance to dig out my scanner I will scan the diagram and post it.
For building the harness Painless wiring has a complete harness for the Mustang mentioned earlier in this thread that would be a good starting point for building a harness for a 460 E40D harness. For over $700 though...
One thing to note about the Cali 460 is that it is OBD2 while the Federal is OBD1
Thanks for the tip on the smog pump.
Will the Cali 460 computer be able to be tuned with Tweecer or would it be better to get a 5.0 computer?
  #251
Old 02-16-2009, 12:38 PM
dutchlincoln79
It's the $700 that makes me having interest in the scematics
When it would be about half of it, i'd consider a buy, but at $700, i definately want to make my own!...
so... When you're finished digging...
Thanks!
  #252
Old 02-17-2009, 01:29 AM
wantaford's Avatar
wantaford
Not sure, I have not investigated that far yet. I have made some mods to my truck and I know I am not fully getting the powergains available because of the limitations of the stock ECM. I need to find out how I can re-program it while not messing anything up for passing California Smog.
  #253
Old 02-17-2009, 01:55 PM
KDPate's Avatar
KDPate
KDPate is offline
1996 and up is OBD-II. Might have to go through the data port under the dash and program with a laptop or hand held tuner..
  #254
Old 02-17-2009, 02:36 PM
jarod17's Avatar
jarod17
jarod17 is offline
Not all '96 trucks are OBD2. My '96 460 has federal emissions and is OBD1. That will change when I am done with the conversion.
  #255
Old 12-03-2009, 12:05 PM
Shawn63200's Avatar
Shawn63200
Shawn63200 is offline
my 97 has the OBD1 as well. Changing that too.
Quick Reply: SD to MAF Conversion - Write up?
