best sct file/tune for mpg around town and highway?
Old 03-16-2007, 12:41 AM
mrholmes's Avatar
mrholmes
mrholmes is offline
does anybody know the best sct file/tune for the best mpg you can get on a 2003 6.0 crew/long bed 4x4....all i want is better mpg.
thanks
tim
Old 03-16-2007, 09:33 AM
2006PSDSD's Avatar
2006PSDSD
2006PSDSD is offline
I got my SCTXcal2 from Innovative Diesel, and the programmer there said, to get the best MPG, use the highest tune you have. For me it would be Extreme Race (most power tune they offer), but I don't want to drive it around town with that tune because of the TC lockup built into the tune. I run mine in the street tune, and get about 13-14 MPG on my '06, most of my driving is in the city though.
Old 03-17-2007, 12:25 AM
mrholmes's Avatar
mrholmes
mrholmes is offline
13-14...i am getting 14mpg on my 2003 06 with it being stock...do you have an exhaust setup or a aftermarket air filter?
Old 03-17-2007, 10:33 AM
2006PSDSD's Avatar
2006PSDSD
I've got an exhaust and the SCTXcal2. I don't recommend replacing your stock air intake, unless your planning on some serious power. The stock intake systems are among the best on the market for the 6.0. You do have a 6.0 right? The exhaust I have is a ATS 4" turbo back system. I should tell you that my truck has only got 10,500 miles on it right now, and my MPG is slowly beginning to increase as the engine breaks in. Your axle gear ratios will effect your MPG as well, I have 3.73's on my SRW, CC, SB F-350.
Old 03-17-2007, 01:19 PM
mrholmes's Avatar
mrholmes
mrholmes is offline
got it...all i did on the air filter system was replae the stock filter with a tru flow filter, since the guy i bought it from had never changed the filter since he bought it and it was freaking filthy...the stock to replace was 80 the true flow was 90...with a lifetime warranntty...makes the turbo whine more thats it so far...just filled up yesterdya will find out mileage later on...last time i checked it was all stock last week and i got 14.4 mpg...mine is an 03 with 75k on it...
Old 03-17-2007, 08:54 PM
2006PSDSD's Avatar
2006PSDSD
Good luck, an exhaust system will help your MPG as well, if your interested in that. The sound of a turbo back is awesome!!!
Old 03-17-2007, 09:47 PM
mrholmes's Avatar
mrholmes
mrholmes is offline
you know it actuallyis not loud at all..i just hear the turbo whine and thats it..it`s not annoying at all..which is what i wanted...i got it from big rolling power brp.com it is 649 and it was easy to install no welding all clamps...which is good cuz i live in mi. and it would rust out on the welds....
Old 03-18-2007, 07:17 AM
MobeyDick's Avatar
MobeyDick
MobeyDick is offline
Stock program!
Old 03-18-2007, 10:22 AM
SpartanDieselTech's Avatar
SpartanDieselTech
SpartanDieselTech is offline
Former Vendor
Originally Posted by MobeyDick
Stock program!
Last time I checked the man asked about SCT programs; so stock really isn't included in this conversation as he did not ask whether or not to get a tuner but what the best calibration file is.
As far as true highway economy, Eric @ Innovative is right about the hotter tunes generally getting the best fuel economy due to higher ICP and injection timing.
We have two specific economy files; one that can be towed with and one that cannot be towed with. The non-towing economy file will yield the best fuel mileage of any of the tunes; but will not yield a huge power increase over stock.
Old 03-21-2007, 08:58 PM
mrholmes's Avatar
mrholmes
mrholmes is offline
help...i got a check engine light--after programing my 6.o and driving it 200 hundred miles the code came up--- p132b---..so i hooked back up the sct and erased the code and then put it back to stock...also ..do i really have to disconect the fuel pump and electric fan fuses...found the fuel pump fuse..but the electric fan fuses? all i found close to that was a 10amp eatc module/front blower relay coil and a 40 amp front blower motor..are those the ones?
thanks
tim
Old 03-22-2007, 08:13 AM
2006PSDSD's Avatar
2006PSDSD
No, you don't have to pull any fuses on the diesels, that's for the gassers. I would remove any trace of your SCT and take the truck to the dealer. Come to think of it, I thought that there was a TSB for any 6 liter tripping that code. Look your truck up in the TSB/Recall section on the top of the FTE home page, and see if there is a TSB for it if you want, or just take it to the dealer and let them figure it out. I like to be a little more informed of what the techs are doing to my baby
Old 03-23-2007, 10:58 PM
ratherbestrokn's Avatar
ratherbestrokn
ratherbestrokn is offline
anyone have any trans problems with the sct? im quite interested in doing a tuner soon and im looking at the xcal2. Just thought id get some input before i bought anything!!
Old 03-23-2007, 11:18 PM
mrxlh's Avatar
mrxlh
mrxlh is offline
No problems with the xcal2, just don't get the lemon.......err I mean the livewire.
Old 03-25-2007, 09:17 AM
2006PSDSD's Avatar
2006PSDSD
My truck shifts 10 times better, with the SCT, than it did stock. Go SCT and you won't regret it.
Old 03-25-2007, 12:29 PM
dapgar's Avatar
dapgar
dapgar is offline
what kind of mileage are you guys with the SCT xcal2 getting? i'm averageing 13-14 stock and that's not highway driving but also not city either, just rural country roads, not a lot of stop and go like the city. traveling 40-50 mph on most roads.
i would love to get mine up to 16 or so and higher on the highway trips.
not sure about putting a tuner on it. i'm not into hotrodding the truck, it's for work. i just want better mileage.
Quick Reply: best sct file/tune for mpg around town and highway?
