Electrical Relay Location
is this pictue out of a 91? I found the ones honney described, but that can't be all... It would appear that I should have a box like you show (where is yours located exactly?).... I am looking for the relay for my brakes (ABS). Both lights (brake & ABS) are on and my repair manual says to service the eletrical side first. That is why I am searching for it.
yo,
that pic is from Ken's 93.
The PDB on the driver's side fenderwell.
On his 93 the (R)ABS fuse is the 2nd from the bottom when viewing from the driver's side front fender. In Ken's pic, see part of the air filter box to the left of the Power Distribution Box?
And here is his complete article with an additional pic of the PDB, master brake cyl, and air box:
http://froggmann.3iii.net/Tech/ABS.htm
Hopefully, someone with a 91 can provide the complete circuitry for your year.
Yep, AIM kinda screwed you up w/the pic of the newer integrated fuse blocks/relays. What you found is all you've got (I've got a '90).
The RABS module is (I think) under the dash in the center, kinda under the stereo. I'm not much help, I hate the RABS and couldn't care less if it works so I've never messed w/mine.
