1978 - 1996 Big Bronco
1996 Ford Bronco whining noise from rear axle
Old 01-24-2002, 01:15 PM
motochick218's Avatar
motochick218
motochick218 is offline
My brother's bronco is making a terrible whining noise
from the rear, it gets louder as you go faster, any
ideas???
Thanks,
Nancy
Old 01-24-2002, 02:04 PM
sideout2's Avatar
sideout2
sideout2 is offline
he needs to check the fluid level in the differential. If it is really low it will cause a whine. If it has been run without gear oil for too long the gears may be really worn and also cause a whine and may need to be replaced.
Old 07-22-2002, 10:47 AM
darthkeebler's Avatar
darthkeebler
darthkeebler is offline
Pull the check plug towards the top of the diff. If there are shavings on the plug (which most likely will be the case) then the rear end could be going out. Top it off with fluid and see if it solves it. If not, the gears are going out, so it time to have it replaced.
Old 07-22-2002, 10:59 AM
adelyser's Avatar
adelyser
adelyser is offline
F150MUTT
2015 - 2020 F150
08-12-2017 02:29 PM
peter p
1997 - 2003 F150
09-07-2015 03:09 PM
cwnitsuj
2004 - 2008 F150
02-12-2013 08:13 PM
xltrangerflex
11-17-2012 09:52 PM
tookey71
1997-2006 Expedition & Navigator
08-10-2011 08:52 AM
Quick Reply: 1996 Ford Bronco whining noise from rear axle
