Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #61 (permalink)
Old 07-15-2007, 10:25 PM
hoxiii's Avatar
hoxiii hoxiii is offline
hoxiii is gaining momentum as a positive member of FTE.
The C6 is quite the unit, the only thing you have to watch out for is that all C6's that came from a car behind an FE use Type F automatic transmission fluid. If you use the common dexron type fluid the life span of the transmission will be shortened AND you will lose performance. The type F fluid makes the older C6's bite harder on shifts.
Justin
__________________
86 150 SuperCab Shortbed 4x4 conversion XLT Lariat, 300, 435
85 150 4x4 convert, 390 FE, NP435, 205, 9" TTB 44
R.I.P 8-26-07
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=161169&.jpg
  #62 (permalink)
Old 08-16-2007, 03:37 PM
69-highboy 69-highboy is offline
69-highboy is starting off with a positive reputation.
Now there's an oldie! I haven't seen an oil filler/breather cap like that in almost 30 years
  #63 (permalink)
Old 08-16-2007, 07:16 PM
hoxiii's Avatar
The manifold is off of a 64 T-bird, i really like it. makes adding oil a snap.
Justin
__________________
R.I.P 8-26-07
  #64 (permalink)
Old 08-16-2007, 09:39 PM
cfrives3 cfrives3 is offline
cfrives3 is starting off with a positive reputation.
sorry, a little off topic. What happens if I screwed up and put type F in my 86 Bronco that has the C-6? It feels like it's slipping to me.
__________________
Charles F. Rives III
65 F-100 2wd-352 4v various mods, pretty quick
83 F-250-Obnoxious 6.9 Diesel on 36's
85 Bronco-still sittin stock, 300 I-6
86 Bronco-Eddie Bauer 408w stroker
  #65 (permalink)
Old 08-16-2007, 10:13 PM
It's my understanding that the "F" in type F stands for friction modified. I've used it in G.M. THM350s and they seem to firm up in the shifting too. FWIW, I've seen THF (tractor hydraulic fluid) dumped into THM350s and they keep on chuggin'. I've seen it, but don't recommend it.
  #66 (permalink)
Old 08-17-2007, 08:14 AM
Quote:
So have I screwed up my tranny or what?
__________________
  #67 (permalink)
Old 08-21-2007, 06:35 PM
hoxiii's Avatar
Type F will actually make a C6 last longer. Ford started recommending dexron/mercon to ease what luxury car buyers deemed "harsh shifts".
Type F fluid won't allow the clutches to clip as much as mercon fluid, so the trans will shift harder and faster- the way it's supposed to.
Justin
__________________
R.I.P 8-26-07
  #68 (permalink)
Old 08-28-2007, 12:13 AM
ford390fe ford390fe is offline
ford390fe is starting off with a positive reputation.
Going back to the header issues, the 4x4 390 headers come down pretty close to the block. Do you think those would work? I have an 85 light duty f-250 that I also am going to swap a 390 into. I will also have it easy to hook up the hydraulic clutch to because I got a bell housing from an F-600 flatbed that has a slave cylinder and eveything on it already. Also do you guys think a an np208 transfer case will hold up to a 390 with a four barrel, RV cam, and possibly headers with a 8.5 comp. ratio? This truck has the tired old six in it and we use it on the farm. Plus I think it would have a fairly decent get up and go attitude. It would kind of be a sleeper. I think I'll post up a thread when I start working on it and also try to get some pictures.
  #69 (permalink)
Old 08-28-2007, 10:49 AM
hoxiii's Avatar
Sad day. Truck is totaled, got stolen last saturday and the guy drove if off of the end of a T in the road. took out a 10" cedar tree, 3 6" oak trees, and came to rest on a 22" oak. Driveline is OK, but the body is shot and the frame is twizler shaped. I'm picking up an 86 now with a worn out 302 that I'm going to put my 300-6 into as i tear down the 390 to make sure nothing got broken in the wreck.
The estimated speed at impact was about 65 MPH. The cab survived remarkably well, but for how much blood was inside the truck, how bent the steering wheel is, and how big of a knee shaped dent in the dashboard there is I don't think the thief fared too well.
Back to the question at hand:
no, 4x4 headers won't work. they drop right into the crossmember. they have to wrap back like 4x2 headers, but if you run a manual the headers i tried dumped right into the clutch fork. The only headers i think would work are the sanderson short tubes for 390 powered galaxies. they fit in the same hole as the stock manifold, so they ::should:: work.
Justin
__________________
R.I.P 8-26-07
  #70 (permalink)
Old 08-28-2007, 11:34 AM
Well see the 85 truck is a manual trans. Justin, were you saying they hit the clutch fork you made yourself?
  #71 (permalink)
Old 08-28-2007, 11:51 AM
hoxiii's Avatar
no, the 4x2 390 headers in a manual transmission 1980 and up truck with a 4 speed the headers will dump into the clutch fork no matter what, or at least if you try to use dynomax headers like I did.
That's the part that confused me, the only parts of my truck meant to go together are the motor and he trans and the trans is the only thing that kept me from putting headers on my truck.
Justin
__________________
R.I.P 8-26-07
  #72 (permalink)
Old 08-28-2007, 02:33 PM
Mtthwvn73's Avatar
Mtthwvn73 Mtthwvn73 is offline
Mtthwvn73 is starting off with a positive reputation.
Man, that sucks about your truck Hoxiii. From the way you describe the truck the guy driving it probably didn't fair too well at all. All that work just to have something like this happen. Are you going to get any money out of it? I'd say not much, but something is better than nothing.
Matt
__________________
1996 F150 4x4 SWB
5.8 MA'd
E4OD tranny
All the options
  #73 (permalink)
Old 08-28-2007, 06:53 PM
hoxiii's Avatar
nah, liability only. i'm not even reporting it. I already tracked down anoth truck for $300, so it'll work out just fine.
Justin
__________________
R.I.P 8-26-07
  #74 (permalink)
Old 08-28-2007, 07:39 PM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
Justin
Man, sorry to hear about your truck! It would seem your beast was too much for him to handle, I guess theres some satisfaction there....
Any plans to re-use the 390?
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #75 (permalink)
Old 08-28-2007, 08:35 PM
hoxiii's Avatar
I'm going to tear the 390 completely down and make sure the block isn't cracked or anything. If it's still good the motor will go back together and be installed.
I know the motor stalled instantly, so it wasn't run without oil or water which is definitely a plus.
The truck had been parked becasue the brakes had been acting goofy. first application nothing would happen, second it'd slow down, and third pump it'd lock up the rear brakes completely.
Justin
__________________
R.I.P 8-26-07
Tags
150 , 1985 , 1985f , 1985f150 , 390 , bell , f150 , fe , ford , housing , lakewood , sale , turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
