To Trim or not to trim, that is the question...
Ok so I have looked all over at 67-72 trucks and I have some questions about the side trim. My 70 has the wide trim in the middle down the sides and then the trim at the bottom and in the wheel well.
What is the difference between my truck, trucks that have the thin middle trim and nothing at the bottom, and then the trucks that have neither.
Secondly, what would I need to do to take a fender that doesn't have trim holes and drill it to get my trim to fit? Should I even do this? I think the trucks look better without the trim on it, but wouldn't this be against FTE religion to take my trim off and bondo over the holes?
Your explanations and opinion as valued as always.
The difference between the trucks are the trip packages, camper special and xlt had wide moldings, sport custom and custom I think had the thin. To put wheel well moldings and a truck not equipped is the mark and drill about 5 holes. But if you hate the molding take it off, my next truck wont have any moldings on the side, its better than driving a Chevy.
Personally I've always liked the mouldings...it's a 60's / 70's thing. These trucks in the right paint colors really stand out with all the flashy trim. The reverse paint scheme is unique, as Ford only offered the darker colors in the center body with lighter roofs and lower body on the 67/72's.
There are several full color books available today on Ford Trucks. I suggest you look at one/all before doing anything to your truck. The books will give you ideas on what to do.
I like the trimless smooth look, "shaved" trim and door handles was some of the first exploits into customizing that a lot of us took when we started. Just a note of caution, though. When you get the trim holes all welded up and smoothed out, you're going to start thinking of other little mods to do.....It becomes one of those never ending things.
Oh yeah, if you weld the holes shut, use a piece of brass as a backer on the hole, then either mig or tig the whole shut. The brass makes the hole filling process a lot easier.....
Originally Posted by MaxKlinger
Wouldn't the dissimilar metals (brass on steel) cause galvanic corrosion at the weld point?
Anyway, I treat all repaired areas with a product called "Phix", worked into the area with a purple scuff pad, then an etch primer followed by an epoxy primer... Maybe something in there kills the corrosion???? Heck, even moisture and oils from touching the metal with your hands can cause corrosion.... Proper preparation to the metal BEFORE applying paint is the key to controlling the corrosion....
I pondered the same exact question.
$600 for new trim or $600 for aloy/chrome rims?????? The wood grain on my trim is all faded and there are lots on dings in it.
My solution came to me real easy. I found(and bought) a truck in better shape without the trim on it. I am going to daily drive the XLT and restore the non-trim one. $600 I don't have will be better used somewhere else.
but it is a tough question and all comes down to personal preferance. I also am not a huge fan of chrome. Also for some reason rust always starts under trim whether its chrome or plastic and whether its bolted/cliped on or stuck on with tape.
My 71 F250 Ranger XLT Camper Special had the wide chrome in the middle and narrower chrome on the bottom (that did not go past the rear wheel). I like the look of the narrow chrome in the middle but would like the wider chrome on the bottom. I priced all the chrome on my truck including the grill and tailgate insert it is around $2000.00. I am filling all the holes except the back of cab molding hood molding and wheel well molding. I am going to paint a solid more modern color (gunmetal dark shadow gray metallic) and then re-drill and add chrome as budget allows (if I still want it). I will probably end up with a Ranger XLT that looks like a Ranger Custom Cab. I am having a hard time deciding what to do with the rain gutters. I like the look of the chrome on the gutters but I can’t seem to find any new chrome for that area. Mine is probably in good enough shape to put back on but it seems to have been pressed on somehow. I am not sure it would go back on. Do any of you have experience with that? Or know where to buy it new?
Chad
Chad
my trim(thin strip) is in pretty good shape for being 71 not realy any dings just faded/polishing needed.when i repaint it again ill put on new trim so everything looks new.nothing looks tackyer than fresh paint and old trim.i know it cost a bunch to replace it but realy dont these ol'trucks look classy in origanal trim?i think that the peice on the front of the hood needs to be there it fills the gap nicly.
Originally Posted by jwcorder
I can't decide what to do. How hard would it be to take a fender that doesn't have trim and drill it so my trim fits??
If you don't have an old fender to go by, then with the fender installed, draw a straight horizontal line off each edge of the door trim along the fender. This can be done with a long straight edge of some kind. Then measure where the clips will be on the trim, transfer these measurements to the center of your two lines, drill the holes.
As with anything else, measure twice, then measure again, stand back and eyeball your marks, then drill.... Check, check, and recheck!!!!
