bucket heater?
Old 04-16-2007, 02:13 PM
superpony18's Avatar
superpony18
superpony18 is offline
bucket heater?
I have read about people using a water heater element and an extension cord to make a bucket heater, is that all there is to it?. My oil is to thick to pump when I get it so I am looking for options. Just rapping up the loose ends on my processor, should be making bio by May.
Old 04-16-2007, 04:13 PM
willbd's Avatar
willbd
willbd is offline
Yes it is. Some people use 220 volt elements. The 200 volt element will not get as hot as the 120 volt element.
Old 04-16-2007, 07:50 PM
Gun-Driver's Avatar
Gun-Driver
Gun-Driver is offline
That’s what I use to heat the oil that is in the 55 gal. drums I have outside the restaurant. It’s a 4500 watt 220 hot water heater that I attached to the end of an extension cord (12 gauge). I threaded it into a 1" iron pipe coupling and attached the ground to the coupling. I just hang it in the drum for about 10 to 20 minutes depending on how cold it is and stir it once in a while. I also use a gas powered 2" trash pump to pump the oil into my drum in the truck.
Old 04-16-2007, 08:11 PM
Talyn's Avatar
Talyn
Talyn is offline
I found someting today that might do the trick. let me upload the picture!
Old 04-16-2007, 08:21 PM
Talyn's Avatar
Talyn
Talyn is offline
Apparently its used to start charcoal by super heating it. It works like a soldering iron.
Says it reaches tempatures of 1000 Deg F.
Which if thats to hot at 120v's (110) then you can always jump it down.
Just like the cooking elements on a stove, or those table top stove/cooker deals.
i figure this would do really good for heating oil if used properly.
Thoughts?
Old 04-16-2007, 08:48 PM
superpony18
Thanks for the responses guys, wanted to make sure before I tried.
Old 04-16-2007, 11:54 PM
CheaperJeeper's Avatar
CheaperJeeper
CheaperJeeper is offline
Thoughts?
I'll wager it won't get anywhere near 1000 degrees when its submerged in liquid. Which is a good thing.....
Old 04-17-2007, 12:02 AM
Talyn's Avatar
Talyn
Talyn is offline
no, but for 9 dollars, it will heat your oil.
Thats the beauty of it!!!
Just drop it in whatever drum you need, and let it do its work.
Old 04-17-2007, 01:41 AM
Gun-Driver's Avatar
Gun-Driver
Basically the same thing I use , I just used the top element out of the hot water tank I was converting. Looks to me like it should work as long as it doesn't get to hot - that would be one heck of a grease fire.
Old 04-17-2007, 09:39 AM
Talyn's Avatar
Talyn
Talyn is offline
Ya, I would have to test it, But i'm not into that phase of the plan yet.
It would be really simple to just drop the voltage lower so it does not get to hot.
The other solution would be to make a double boiler setup, and heat the oil with boiling water. That is overly compliacated however.
Zazoos
1999 to 2016 Super Duty
05-19-2015 02:59 PM
bowtieman55
WTB - Parts & other
04-29-2015 10:32 PM
4x4 Bart
44
03-07-2014 12:39 PM
hitec
New Member Introductions
11-25-2006 08:33 AM
cebru
10-03-2004 05:07 PM
Quick Reply: bucket heater?
