I was told to replace my plugs with a cooler plug when I installed my 4lb pulley. Any suggestion as to using a anti-seize, or loctite when installing new plugs?
Use a light coating of anit sieze. If you don't the steel plug threads might develop a permanent relationship with the aluminum head. Do not over torque the plugs, the heads are known to have weak threads.
