A New Brownie thread . . .
#183
7041 Spicer "A"-Box
Hi - I found "A-Boxes very hard to find in B.C. I Asked everyone I could think of without much luck. Finally a friend told me he new of a person off Westside Rd., between Vernon and Kelowna,, that had a burned 60's Ford tandem. The second one I found at Mountain High, a truck shop in Salmon Arm. This one was in a Chev. tandem. I removed both units myself. These were the only two I found.
The 7041's were available in one gear set only.
1st = 2.31, 2nd = 1.21, 3rd = 1.00, 4th = 0.83
#185
A New Brownie thread ...
Hi again. That's a hard question to answer. Kinda depends on where you live. I think one is better off if you can find one still in a truck and take it out yourself, that way you can take everything you need,trans,mounts, shift rods,remote & drive shafts. You will notice in my pics that trans is rubber mounted and mounts are adjustable to get proper shaft angles. If not mounted properly vibrations could be a problem. What do you want to put one in and why? Where do you live? Bye for now
#186
Biggest thing keeping me from diving into this project is time, money, and availibility of parts in my area.
#187
I've got my granddad's '48 International KB-6 sitting out in the "back 40" that I'm getting colser and closer to restoring all the time. I want to use the original Red Diamond engine, and 4 speed transmission. Problem is it's geared for 45 mph, no more. Plus, pawpaw Jimmy always complained about it's narrow powerband, and only 4 gears, leaving you having to choose between revving the engine near redline, or lugging it to death.
#188
KB-6 Is a 2 ton. IH's ratings were much (if not exactly) the same as Ford's F-Series of the era.
KB-1= 1/2 ton
KB-2= 3/4 ton
KB-3= 1 ton
KB-4= 1 1/4 ton
KB-5= 1 1/2 ton
KB-6= 2 ton
KB-7= 2 1-2 ton
They went all the way on up to a KB-12, if I've heard correctly. I talked to a guy at the Portland IN Tri-State Tractor & Engine Show and Swap Meet this past August who had a KB-10. His was outfitted much like a single axle tractor with a 5th weel, and saddle tanks. I think his had 22.5" Budd wheels too, but I'm not sure. My KB-6 has the tank inside the cab, and 20" stud-pilot, split-rim wheels.
KB-1= 1/2 ton
KB-2= 3/4 ton
KB-3= 1 ton
KB-4= 1 1/4 ton
KB-5= 1 1/2 ton
KB-6= 2 ton
KB-7= 2 1-2 ton
#189
Hi again Sounds like a KB-6 would be about the same size or a bit heavier than my Merc. C-500. the truck I put the 7041 into in the above pics. With your combination I believe an "A" box would work well. One with about a .73 over would probably be better than the 7041, would be a bit faster. A 3spd. would work as well as a 4spd. as you don't use 1st. in a 4spd. very often anyway.
I have a 3spd. "A"-box from an IH. Believe it was in about a 64 V-Liner tandem but not sure. It is a very heavy unit, much heavier than 7041. Would sell it for $100.00 but don't think it would go well in a KB-6. I think it is .73 over but to heavy. A 6031 or 6041 Spicer would probably be best I think. Will need to study this a bit more. If I goofed will let you know here. Bye for now
#191
