03 f-150 wont shift into 4wd
I replaced my vacuum lines for the same reason...Everything sounded allright when I switched to four wheel(i.e. transfer case engaged, light came on) but i still had no 4 wheel drive. I opened the hood and listened on the right side at the fire wall I had a vacuum leak(cracked lines). Check that
