TC lockup mod questions
Hey guys, first off does anyone have or know where i can find a set of directions to do this mod? i found this one http://www.guzzle.rbmicro.com/tclock.html but I like to look at a few and compare notes. Secondly, which wire from the PCM controlls the T/C?
thanks alot guys!
Robb
thanks alot guys!
Robb
Jboard is correct just hook a wire to the purple and yellow wire. Then just hook it to a switch. All it takes is a ground for the TC to lock. Dont flip your switch to lock it under 25mph though, it can cause the truck to stall, and defanitly do flip the switch sitting still or at a stop light, this is about like dumoing the clutch on a standard. I havent found too much use for the mod though, but if making a exhaust brake out of the EBPV then the TC mod is a must and works good.
Robbgt. Here are two useful links
http://forgotton.net/mods/tclock/index.htm<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
http://www.dieselinnovations.com/techfiles/tclockup.pdf
<o>And my OD off light does not blink with this mod. I also only uses it with the DIY exhaust brake. </o>
<o></o>
<o>I hope it helps you.
</o>
<o></o>
</o>
Hey thanks for the help guys! today i climbed under the truck and found the purple wire w/ yellow tracer and spliced into it and ran it into the cab. I have a spare toggle switch in the cab with (power, load and ground) so i connectedted the (Power) to a ground and connected the wire i tapped to the (load) and left the ground empty. Flip the switch and t/c locks up. Works great. again appreciate the help.
Robb
EDIT: as a note, the od OFF light doesn't blink as a result of this mod.
Robb
Originally Posted by 79f-250custom
now do you just splice into it or just cut the wire in half?
Mitch
ohh and where did you find that wire at? i would like to do this next when i get my truck RUNNING AGAIN.
Mitch
Mitch
Mitch
Robb
