cold start solenoid
Received 3,113 Likes
on
under the alternator, next to the injector pump is the temp sensor for the high idle and timing advance. make sure it is plugged in. it is hard to reach, a pair of needlenose pliers will help. if the wire is loose on the sensor, they both will not work.
i did not even realize mine was off and not working till i put glow plugs in last year and saw the plug off of it.
Remember the cold start solenoid/Fast idle solenoid does NOT push the fuel lever..... you must step on the fuel pedal and with the key on the FI solenoid will fill in the space and hold it on until the Engine temp switch opens and shuts of power at 112*f. Tell Ford you want it for $97.45 or you'll get it of the net.
E5TZ12B526A $129.93 sell $97.45
Fuel system - Fuel induction - Diesel injection pump - Idle speed control
IDLE SPEED CONTROL, E250-350 Vans, w/o Tachometer 1992 - 1996
There is a Ford advertiser on this forum states "lowest prices" let's see if he steps up to the plate........ check for him..... 1-800-532-0819 Pacific Standard Time... the part # does not come up on his search feature.
I wonder if anyone modifies their truck to handle actually moving the throttle lever on its own? When I remote start my 91 7.3 f250 in the cold it doesn't get up to the desired 900 or so cold idle RPM until I go out and press the throttle. Would be nice if that wasn't the case and it idled high (until warmup) from the remote.
[QUOTE=casscodiesel]i have been trying to figure that one out because i have had some starting, running issues, but i had mine disconnected and it ran. then i ran it out of gas. Somewhere it said that the cold start solinoide removes air from the injection pump. . is that true?[/QUOTE
In a word, NO
In a word, NO
