53 F100 Fenders
I haven't bought fenders from them, but Mid-Fifty is one of the most trusted vendors for all our parts, according to reports from members of this forum.
It is generally accepted that all of the fenders are made by one or two sources, so price is really the most important criteria. The quality seems to be the same between different vendors.
Welcome to FTE!!!
Welcome to FTE!!!
As a rule, original stock fenders fit better, but I haven't heard of anyone using aftermarket fenders, except rear fiberglass fenders who have had a problem and even with the fiberglass, I don't recall anyone having problems. I'm with Randy, Mid Fifty have been around for a while and have a reputation. If it's not right, the'll make it right.
Are you talking steel or glass? I won a set at the F100 nationals in 05. They are pretty good. What I have found is they have to worked in the inner area where the gravel pan mounts to them. Randy is correct there are only two or three sources making the steel ones. Either way, reproduction or used you will have to put in some sweat equity. Just a matter of how much you want to do.
If you have any questions about anything MF sells, give them a call and ask. Sy and the gals will tell you the truth even if it's "they are a piece of s*** but it's the best we can find...". They have hands on experience with all their parts and really care about customer satisfaction more than making a sale.
Steel is the way to go even if forced to buy Carp from china. However, for those wanting glass, keep in mind that the new owner of Fairlane has upgraded quality of all the parts they make, so all the history on glass may not apply across the board as it did in past. This is NOT a plug for any company. I do agree with overall opinion on Mid Fifty and used them a lot with never a negative issue. J
Received 4,135 Likes
on
Just my 2 cents worth, in a post I started intitled Frustrating day, I am in the process of installing a set of remanufactured steel front fenders,gravel pan and air deflecters. The parts all look great, The right side fits almost perfect except I will have to do a little cut and weld to the top of the deflecter to allow it to meet where it bolts to the fender, the holes in the gravel pan will have to be enlarged a bit to allow the bolts to fit (both sides). The left side is not working out as well with regards to things lining up but I think that most of the problem is with the air deflecter, the three bottom holes line up horizontilly but are 1/2 inch lower than the holes in the gravel pan, and the holes that bolt to the fender will need to be moved. Where the fenders bolt to the gravel pan there is a bit of a gap but thought I could use some fender welting to fill that. You will have no problem dealing with Midfifty as far as I'm concerned,that's who I bought mine from. I've accepted the fact that there is going to be some finnessing to get them to fit perfectly but when I consider what I had well it's a no brainer. The fenders in my opinion are worth buying.
John
John
