Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-28-2007, 12:12 AM
mongo75's Avatar
mongo75 mongo75 is offline
Garage is empty, add now
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
danny jones
Who's converted a 7.3 to WVO?
I hate to ask similar questions over and over, but hopefully this post will answer some questions for me and others. The wife (PITA) won't let me filter WVO at the house, let alone make bio, so I gotta go SVO ($1.25 a gal) I would like to know who's converted a 7.3 to run WVO, and what you used to do it. I have a 100 gal tank, and plan on using a hotfox to a vormax to a vegitherm, and then to the heads, but I'm taking any and all suggestions!!
While I do appreciate the effort others who now sell conversions have gone through, I just can't see spending $2700 for some parts I could gather for 1/4 to 1/3 the cost.
My biggest question is how did you hook up your fuel lines, and what size are the fuel ports in the heads (I think #4?)
Thanks for the help in helping your fellow members out!
__________________
Danny PAA member #12
SoCal Chapter Member
E99 F-350 Dually Van turbo 4x4 CC LB 7.3L, AFE intake, 3 gauge pillar, 4" Magnaflow SS str8-pipe, DP Tuner, Swamps 175/146 SS inj, ARP head and bottom studs, Comp 910 springs, ITP Ovrbst, CCV mod, SS HPX, home made Reg-return, Foil Del, ZooDad, Air Horns 320hp/704tq
  #2 (permalink)
Old 02-28-2007, 08:38 AM
Oregon-Mike Oregon-Mike is offline
Oregon-Mike is starting off with a positive reputation.
Mongo75,
I can't help you with your question, but I for one am very interested to see how you proceed. I just picked up an old NA 7.3 and am considering going the WVO route at this point. I don't have the space or support (read: maybe my wife is your wife's sister?) to brew the BD at home. I plan on running BD in the main tanks at some point, but I'm going to have to get into some sort of co-op first. Around here there's only one BD pump, it's a long ways from the house and B100 is $.60/gallon higher than dino diesel. I can buy it in jugs closer to home so plan on buying B100 and mixing it myself in the tanks to B5-10 instead of buying DieselKleen for lube.
So seeing as how you can't filter at home, you're just going to buy pre-filtered, de-watered VO from a retail/wholesale source? That seems a little iffy unless the outfit is specifically filtering for fuel use.
Anyway, keep us posted with pics/write-ups.
Mike
__________________
1993 F350, NA 7.3, CC DRW, E4OD tranny with 4.10s.
  #3 (permalink)
Old 02-28-2007, 09:04 AM
wvoburner wvoburner is offline
wvoburner is starting off with a positive reputation.
I'm just getting started on my journey to conversion - but, I know for a fact that you can get a Racor 2 micron filter with a 12v 200w heater built in for about $190.
My initial fuel circuit will have 2) 3 way & 1) on/off solenoid valves with a timed purge cycle, alarm, 2) needle valves to act as flow restrictors, & pretty lights. I am thinking of doing the prototype work on my nephews truck - just kidding.
I am also prototyping an all aluminum retrofit tank heat exchanger-fuel pickup-temp gauge-oil level gauge-cleanout-5 micron reusable filter-plus storage for stuff product that should reduce the cost of an equivalent fuel tank by at least $250. But, you will have to do the retrofit yourself (drill holes above the oil level & bolt in). This may be of absolutely no use to you but I enjoyed crowing a bit.
So, yeah, the bits & pieces needed to put together a DIY conversion probably wont top the $1K mark - I'm hopin' . . . . .
  #4 (permalink)
Old 02-28-2007, 10:09 AM
FN74's Avatar
FN74 FN74 is offline
FN74 is gaining momentum as a positive member of FTE.FN74 is gaining momentum as a positive member of FTE.
Mongo- I only wish I had my stuff marked up 400%. If so, then I wouldn't be worried about how to pay my mortgage every month. Seems to be a huge misconception that All we do is buy junk, throw a massive markup on it, and kick it out the door. Never mind the 2.5 years of R&D, Custom made parts, 2 year warranty, and all the work being done. Besides spending again alomost 2 years sourcing the correct parts, doing all the research to find out what works and what doesn't. Not to sound arrogant, but i was the first one to do the complete second stand alone fuel system straight to the heads on the PSD, and wound up in business due to lots of people wanting one. Do some research on the source of Vegistroke. Now, getting off my Soapbox a bit, I started the same way and for the same reasons. I didn't want to pay for what was already out there. Thought I could do it cheaper and better. I was only half right. Better yes, cheaper no.
You will find the pump to be your single highest failure item, and should invest in a good pump. I have gone through many Aeromotives, and Mallory's, and stock pumps. As of right now there is only one with a warranty for use with WVO, and that is the Fass. Make sure you use a good Fire Resistant bio compatible hose such as the Parker 820FR series for on the motor. The rest of it can be a little cheaper. If you do traditional HIH, you will need to use special compression fittings, and the right kind of Aluminum tube, or it WILL leak, or the aluminum will become brittle and crack. For the PSD, HOH is quite sufficient so long as you do not have long exposed lengths of fuel line. The HotFox is OK as a tank heater, and industructible. If you live in a very cold climate i would recomend Line-X or insulation for the tank. If you go straight to the heads, the ports are 1/8NPT, but you will need check valves on the OEM fuel lines to prevent backfeed. There are stock ones, but they do not function as true check valves, and will allow backflow. Also, you will either need your WVO pressure at least 25 psi higher than the diesel pressure to fully overcome any diesel usage, or a means of shutting off the Diesel Pump. I use a pressure switch for this purpose to automate things. Make sure the engine is at least 160 before switching to ensure minimal coking. Colder temps than that and you will have gradual coking issues. Each fuel rail holds about 1.5 ounces of fuel, and each injector just under over an 1/8ounce. The motor uses about 1oz/minute at an idle. If you have a means of flusing the fuel rails, you can purge at an idle in about a minute. If not, then it will take closer to 5 minutes at an idle to purge. 1/4" lines are more than enough to feed each 1/8 port as well. Hopefully that helps you out a bit.
__________________
[color=black][size=2]2008 F-250 King Ranch
Engine stuff, Drivetrain stuff
Appearance stuff, Vegg Oil Stuff
  #5 (permalink)
Old 03-01-2007, 07:37 AM
Thumbs up
re: FN74,
My two cents -
Personally I have been involved in product R&D, prototyping, and ultimately production - IT IS WORK! Not just plain old drag your butt out of bed work but waking up at 0200 with your brain in overdrive, tearing your hair out, drinking Maalox like water work! Not to mention the financial risks! Personally, I LOVE it! But, in the end, selling hard parts for a living aint gonna get you to the big house on the hill. If you arent a very clever DYI guy, go with a kit that has a good rep -
  #6 (permalink)
Old 03-01-2007, 11:49 AM
bronco252 bronco252 is offline
bronco252 is starting off with a positive reputation.
Where do you buy SVO for $1.25 a gallon?
  #7 (permalink)
Old 03-01-2007, 06:05 PM
mongo75's Avatar
danny jones
Jason, thanks for the info. I sent you an email this morning (you'll know who by my avatar). Believe me, I do applaud and appreciate your hard work and R&D, as most of us just don't have the time or resources to further our "cause" if you wanna call it that. I'm waiting for your response in the hopes I can throw some business your way, 'cause you can't beat that FN74!
Bronco, there's a guy in ebay that has an auction for soy oil, says he gets 1000 gallons a month, and at the starting bid it works out to about $1.25 a gallon. Trouble is, it wouldn't be worth it to have it shipped, his company isn't too far from where I live in California.
__________________
  #8 (permalink)
Old 03-01-2007, 08:21 PM
FN74's Avatar
WVOburner- Thanks for the props!! Beleive me I had no misconceptions about making it big, but being in business for yourself is a big bonus. All of a sudden the stuff that didn't matter when you work for someone else does matter.
Mongo- Gotcha! I should have put 2 and 2 together. I will respond to your email after a bit. Believe me, originally I didn't have the time or money to further my cause either, but when i kept breaking down, or bfreaking stuff, didn't have much choice. Then it became a matter of principle. No way the oil and the truck were going to get the better of me!!
__________________
  #9 (permalink)
Old 03-01-2007, 11:32 PM
mongo75's Avatar
danny jones
Jason- I like your determination! Wite back when you can.
Dan
__________________
  #10 (permalink)
Old 03-02-2007, 11:16 PM
Cool6.9DieselGuy Cool6.9DieselGuy is offline
Cool6.9DieselGuy is starting off with a positive reputation.
my advice is find flyboy, he runs straight WVO in his 7.3 and his system is absolutely killer w/ no problems at all, he's been doing this for a year or 2 now and has already been through the ups and downs of trying to convert he can tell you what and what not to do.
  #11 (permalink)
Old 03-03-2007, 08:44 AM
flyboyd8 flyboyd8 is offline
flyboyd8 is starting off with a positive reputation.
Time!!!!!!!!!!!!! yes if you want to do a DIY,,,,,,,,,, The word TIME, will have a hole new meaning to you.
Yes, I have successfully run over 25K on a DIY WVO system. I have a "rustfree" 93, 7.3 NA, that I bought out of the salt belt to convert and run on WVO. I am successful, and have always been, but I have made many changes to my system as shortcomings showed up. My ride now has 204K on it and I plan on driving it for 10+ more yrs.
Unless you have a great amount of FREE time, and are bored to death! I would recommend one of the Kits to convert.
For a 6.9 or 7.3 IDI NA or Turbo. I would look real close at the Grease Car Kit w/ 40 gal. heated tank for $1100.00. That is only the equivalent to 350 gal. of dino diesel. They are from Haley Mass. that is in the cold north east! I currently run their solenoid valves. they are Perfect "IMOA".
Planet Drive also has very good systems, I use some of there parts also, Good Stuff!!!
You PSD guys, Listen to Erick and FN74, """"""TIME"""""" and some one to talk to because you may not have the time to experiment. Not to mention Money
What ever system you decide to go with, Don't cut corners!!!!!!!!! you need 158*+ Vo temp when it gets to the injectors!
I have both coolant and 12v elect. I have a Artic Fox heated 100 gal. tank, run 3/8" steel fuel line inside of 3/4 heater hose. a VegPower Hothead filter with a 80 watt 12v blanket heater on the bottom of my filter also has insulation blaket around it for winter, more heated fuel line to the solenoid valve, then the lift pump to a Mega vegtherm then onto the IP just before the IP I have two tees in the line 3" before the IP one has a temp gauge the other a boost gauge, I know what my fuel temp is and also press. at the IP. I have a high limit switch and a manual switch for the Mega Vegtherm. there is another Grease Car solenoid valve at the end of the return tee, back of motor, the system will purge fro VO to diesel in 20 seconds. with a SPDT switch I sequence the valves and have no mixing of WVO and Dino, in my dino tanks. I can return diesel to the WVO tank if I want My return line is a 5/16" steel line inside 3/4" HH that also helps heat the WVO tank. in the summer I run w/ just coolant heat and easily maintain 180 at the IP. All lines are insulated with foam pipe insulation. The Lines from my tank to the filter under the hood is +- 16'. from filter to valve +- 4' . Don't forget the cost of all them Compresion fittings and hose barbs. I have a lathe and customized a lot of my fittings. TIME!!!!!!!!!!
If you return any WVO to your diesel tank/ tanks you will be putting one of the best solvents known to man in those tanks and don't be surprised when it loosens up every bit of the **** that was deposited by the dino fuel and tries to run it threw your dino filter all at once. You will end up with clean tanks and you will be changing dino filters with every tank of dino fuel until you get it all out. Go ahead ask me how I know.
IMHO the Pollack valves will not stand 160+ degree fuel for long, I have removed two six ways, and now have installed the correct way to do it, reliable, and no WVO back to the diesel tank, not that it would matter now, other than it would be cold oil in the winter.
You should know your system completely, I have never been stranded, or worried about reliability.
IMHO you don't want any WVO spills under the hood or in the cab,( I read that on this site a long time ago and have followed that advice to the letter) the stuff will always be there. I will not even get in the truck with my filtering coveralls on! I helped a stranded driver the other day, he had neatly parked his truck way off the road, something about going to fast and slippery wet snow.. He hesitated to get into my truck because it was so clean and nice. He had no Idea It was running on WVO and I didn't tell.
I heat my WVO for 48 hours min. in an open top heater, then it is filtered threw 4 different filtering devices before it goes into my truck. or the tractors. or to storage.
Long live the IDI,
Shoot often, shoot safe, shoot with new people!! Illegal aliens are just that ILLEGAL!!!!Get rid of them.... Don't ever ask me to press one!
I have no decals or signs about WVO on my truck, something about road tax.
Ken in Central NY
__________________
Ken, Central NY
Mighty Pre-94, (93) F250, 2wd, 7.3 N/A, E4OD, 3.55, ext. cab, 333K hit 333,333.33 on 6-12-11 @ 2:14PM EST, Last 153k on WVO.
  #12 (permalink)
Old 03-03-2007, 11:42 PM
hey Ken I never did ask you, how old are you?
  #13 (permalink)
Old 03-04-2007, 06:03 AM
Old enough to remember Vietnam, Old enough to remember $.09 diesel fuel, Old enough to know the value of "Time" . Old enough to have flown R/C airplanes for 27 yrs. Old enough to know what and were Ellis Island is! and on and on.
__________________
Ken, Central NY
  #14 (permalink)
Old 03-04-2007, 07:27 AM
Appologies for not understanding anacronyms like 'IMOA'. I always thought it meant 'Iterative Maximum Overlap Approximation' but I cant see how that would relate to this discussion - a little help please? Thanks
  #15 (permalink)
Old 03-04-2007, 08:02 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
Google Forum Acronyms.
This was one of the sites that came up
Erick
Tags
1993, 73, f250, fn74, ford, fuel, idi, leaving, line, list, overnight, parts, return, routing, start, vegitherm, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
