AC Low side Identification
its on or very near the accumulator which is back LHS of motor next to air heater box when facing rear of vehicle with hood up.
From the LH end of the Radiator, follow a steel then plastic hose towards the back of the compartment to the accumulator - it'll be on or near it. Look for a black plastic cap.
Do you have r-12 or r-134a? The 12 will have screw on fittings of the same size. The 134a will have quick disconnect connectors of 2 different sizes. The low pressure side will be the smaller of the two and may have a blue cap on it. My geuss is that you have r-12. If you charge the system yourself be sure to get the right type of freon or get one that will mix with your type. You cannot buy r-12 w/o an a/c permit but they do have freon that will mix at most of your local parts stores. If your having to recharge you most likely have a leak, so you'll be doing this again in the near future, depending on how big the leak is.
If you have r-12 the best thing you can do is convert it to 134a. You'll need to replace the orifice tube,drier/accumulator, and the compressor. Then you flush the the lines, condensor, and evaporator core; you can flush the compressor and change the oil in it but with the miles you probably have on it you'll be better to replace it. The entire conversion, if done by you, will take a saturday and about $500 to $750 in parts. If you take it to the shop it'll cost double or more, unless the shop has r-12 left in stock and can find and seal the leak. The last time I went to buy r-12 the price was around $110 a pound, this due to the fact it's no longer made and all that is left is in controlled distribution from the govt through the old manufacturers( mainly dupont).
Michael Ward
06-01-2017 10:06 AM
Whitey Ford
10-19-2015 10:16 PM
AlreadyGone
07-27-2003 06:41 PM
