Need help wiring an E4od controller
Can anyone help me with an E4OD wiring diagram? I have the tranny in my truck with the tranny wireing harness. I have the speed sensor input from my rear axle and I have the Throttle Position on the Injection pump. I have the Computer or the PCM and the original harness. Let me explain my dilema. I purchased a rolled 92 f-350 diesel with the E40d. I removed all the sheet metal (cab and bed) and had an 87 cab and bed from another diesel. I did keep the wiring harness from the 92 its in a box with the PCM. I should be able to use the connector for the pcm and wire in the Tranny wires about 12 of them, the Speed sensor, the TPS and 12 volts. I just dont know were to start. PLease help if you can..
Thanx in advance.
Thanx in advance.
This is out of my 1992 shop manual. I think this is for the Diesel. It said EEC but did not specify an engine type and there are diagrams for all the other gas engines. By elimination it must be the Diesel. Maybe someone can verify?
I don't see any transmission related wiring on this. Do Diesels have a separate transmission controller?
