Kentucky Chapter Join Chapter, Leader: SideWinder4.9l
Is here a thing of 351 HO?
Old 02-17-2007, 07:03 PM
cmaupin's Avatar
cmaupin
cmaupin is offline
Exclamation Is here a thing of 351 HO?
I am looking in buying a 1986 F150, to replace my 81 f100 both are 4x4. The guy said that the motor is a 351 HO. I have looked and looked and have not found anything that says there is a 351 ho in pick-ups. Some in the police cars. My question is if the motor is a 351 HO, is it a cleveland or winsor ? Thanks
Charles
Old 02-18-2007, 12:54 PM
Bobs55effie's Avatar
Bobs55effie
Bobs55effie is offline
Charles
Ifyou can't get your answer here, you may want to check with sbftech.com There are some really good engine guys over there.
Good Luck!
Old 02-18-2007, 09:20 PM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
I had one that was swapped into a work van. It's a Windsor engine if I remember correctly
Old 02-19-2007, 04:29 PM
kenpobuck's Avatar
kenpobuck
kenpobuck is offline
Yes they are a windsor engine and yes they did come in trucks. I have seen them in some of the broncos.
Old 02-20-2007, 04:07 PM
Bluehawk's Avatar
Bluehawk
Bluehawk is offline
I had an '85 Bronco with a 351 HO engine. It was a 351 Winsor, not sure what made it the HO, but that is what the air cleaner cover said. It is not an easy motor to find.
Bluehawk
Old 03-22-2007, 12:02 PM
harold morgan's Avatar
harold morgan
harold morgan is offline
check your vin # for a Y to verify it an HO.
Old 03-23-2007, 08:33 PM
79_effie's Avatar
79_effie
79_effie is offline
If I'm not mistaken, the HO had a 4 barrel carb whereas the standard 351 had a 2 barrel. If there were any other differences I'm not sure.
Old 03-23-2007, 10:35 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It had a 4bbl Holley carb and a marine camshaft. I've seen them in 85-87 trucks. The air cleaner says 351 4V HO
Old 05-16-2007, 07:41 PM
uriah's Avatar
uriah
uriah is offline
Yep, 351W with a Holley and different cam.
Old 05-21-2007, 01:11 AM
4starcstms's Avatar
4starcstms
4starcstms is offline
Roller cam wasnt it??/
Old 05-21-2007, 09:13 AM
rywegh's Avatar
rywegh
rywegh is offline
Thats what I was getting ready to suggest as I recall reading something about the rollercam also.
Old 05-21-2007, 02:11 PM
4starcstms's Avatar
4starcstms
im 99% sure the 302 HO's were roller motors, I dont see why the 351's were'nt. Keep that in mind when shopping for cams and engine parts.
Old 05-22-2007, 06:24 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
No it was not a roller, those didn't appear until the mid 90's. It is a standard flat tappet hydraulic cam with more lift and duration than the standard 351W. It is actually a torque building cam that was designed for boat engines IE: marine cam.
cbr3
02-14-2012 06:19 PM
corner27
09-22-2010 10:27 PM
hansol04
09-04-2010 12:27 PM
furz4
02-06-2004 11:35 AM
85351ho
22
02-22-2000 03:29 PM
Quick Reply: Is here a thing of 351 HO?
