2.8 info
on
The 2.9 derived from the 2.8 but there are some major differences. Some of these are:
2.8 was carbed, 2.9 was injected.
2.8 had a gear-driven cam with solid lifters, the 2.9 had a chain-drive cam with hydraulic lifters. The cams rotate in opposite directions between the two engines. The valve arrangement is also different.
The 2.8 was German-designed, sort of an extension of the 1.7 V4 of the Ford Taunus and certain Saab models. It was commonly found in the Mercury Capri and then was used in the Ranger till it was replaced by the 2.9.
That's about it off the top of my head, let me know if you have any specific questions. If I don't know the answer I'll make something up!
on
Years ago I rode in a Sunbeam Alpine that had a turboed 2.8 swapped into it. Talk about a fast little car! The guy had built all his own hardware, but with the popularity of the 2.8 powered Mercury Capri of the '70s I know there's a decent aftermarket for them, and there's virtually no difference in the motor itself between the Capri and Ranger.
Personally, I don't deal with Racer Walsh anymore after getting burned by them on parts back when I was racing, but perhaps their customer service has improved since then...
2.8 build up
Hey rodger. I have raced a 2.8 mercury capri of 16 years. It is about the most bullet proof engine I have ever seen. Weak points are the rods which can be fixed with arp rod bolts and the cam drive that can be fixed with an aluminum billet set, not expensive about $50 to $60 dollars. As far as forced induction that is another story. I can be done either turbo or supercharger if you can find the parts. The problem is the head bolt pattern, it is not good enough to hold the pressure. You need to O ring the head and the block. Best company I know of is Burton performance in Liverpool England at www. burtonpower.com. There is also a handbook call V6 performance and covers not only the 2.8 ford but just about any thing that came out of europe. It is out dated as far as part #'s but the information is good.
Well bucklee I am not real sure on that part. Most of the difference's in the two engines are internal. If you are going to pull it apart anyway just lay them side by side and measure. To really make the intake work if it does fit is to match the port which is a little work but does make a difference even if the motor is dead stock. Check with offenhauser and see if they show a different intake of the two engines. If not then I think it will fit.
