Bronco II Ford Bronco II
EGR tube repair
Old 02-04-2007, 03:39 PM
lugnut05's Avatar
lugnut05
lugnut05 is offline
EGR tube repair
I tried this repair on my EGR heat tube and it worked like a champ.
It also saved me the $150.00 Ford wanted for the replacement part.
Like most it was broken off at the exhaust manifold.
I removed the upper flare fitting at the intake plenum, and measured the ID of the tubing. It was .550 ".
I found a piece of 1/2" (.500") O.D. copper tubing ( it would be considered 3/8" copper pipe ) and cut it to about a 2" length.
I then expanded the ID using a tapered drift so that it's O.D. measured .545".
I inserted the copper tube into the heat tube and then the whole assy back into the manifold. It should go right together and be an interference fit.
Re-install the top fitting into the plenum and you're good to go !
rwsam
13
07-25-2019 10:10 AM
Joeblowv1
05-06-2016 07:23 PM
Dago Red
05-06-2016 02:50 PM
wheelieking
01-05-2015 12:20 PM
freightdogfred
15
12-06-2008 07:49 AM
Quick Reply: EGR tube repair
