Clutch, Pressure Plate, & throwout Brearing
To do this by yourself using the aforementioned method just tighten the pressure plate bolts finger tight. this allows for a l;ittle finessing of the tranny which makes it much easier. Then go in through your inspection cover to tighten the pressure plate bolts. I have used this method many times and it has never failed me. Good luck.
I installed it tonight. It went very smooth. I also finish rebuilding the car with Story. The PO stripped the inlet thread for the fuel line so we had to retap and seal with jb weld. I will let it sit until Monday and then install the carb. I also mounted the coil. It looks good. I will take some pics tomorrow and post them
Thanks for the help
Kevin
Thanks for the help
Kevin
Thanks for the help
Kevin
Thanks for the help
Kevin
As far as the carb, you may want to try this; JB won't last very long, could be inviting an engine fire:
"The answer to the leaking fuel line fitting problem is as close as your local NAPA store. Ask for p/n 2-93, it is a repair fitting that will cut it's own thread and convert's to a AN type seat, the line nut that screws into it is p/n 105-5 for 5/16 fuel line.
The fitting cost $6.63 and the nut was 13 cents. "
(clipped from an old thread) I think this particular part was for a Holley 94, but they have one for every common thread size.
brepei
09-30-2015 12:35 PM
53fordman1
09-29-2015 10:05 AM
Peavey1986
01-05-2014 08:58 PM
