How do you bleed the air out of a 2.3L engine?
Fill up the radiator until it won't take any more. I strongly recommend a "spill free funnel".. about $20 from most parts stores.. if you use one, fill the funnel about 1/3 of the way.
Start the engine.. do NOT rev it.. let it idle. Turn full heat on LOW speed on VENT setting. Periodically watch the temp gauge.. if it starts to go above 3/4 shut off the engine and let it cool off a bit (30 min or so) and try again.
It will take much much longer than 15 minutes to warm up on a cold day. Periodically feel the upper radiator hose and the air being blown out by the rad fan. Once these get hot, the thermostat is open. You may experience some antifreeze boiling out JUST BEFORE the thermostat opens.. this is normal, however if it does this more than 30 seconds or so and the thermostat is still not open... SHUT OFF THE ENGINE.
Once the thermostat opens it will suck down a BUNCH more antifreeze, just keep adding until it won't take anymore. The first time the thermostat will not stay open long... let it keep running until it opens again. Add more antifreeze... then install radiator cap and fill the plastic tank about 2/3 of the way full.
ALSO once the thermostat is open, check the heat inside the cab. If it is blowing cold air you still have air trapped.
Another option is to remove the thermostat, and while the housing is disconnected, fill up the cooling system until antifreeze spills out of the thermostat hole.. then install the thermostat. This will purge 99% of the air out of the system. If you choose this method install a new thermostat while you're at it.
Good luck.
Good luck.
hurst1979olds
04-20-2016 11:11 AM
zoti
1983 - 2012 Ranger & B-Series
26
02-28-2006 06:40 PM
