Looking for help with fuel injected into my '67 Ranchero.
Old 06-04-2001, 09:48 PM
laros's Avatar
laros
laros is offline
I am looking to put a 1986 fuel injected high output 302 into my Ranchero. I was curious about what is needed for this kind of swap and if the brain box from MSD or Mallory or a similar company would replace the brain that went with the original mustang. Also is it possible to bypass all the sensors on the fuel injected engine and still have it run good. Any additional information about this type of project would be very much appreciated. Thank you all.
Larry
Old 06-05-2001, 04:43 PM
jimarlie's Avatar
jimarlie
jimarlie is offline
Larry,
best bet would be to ask that question in the small block engine forum. Good luck with your project.
Jim
Old 06-15-2001, 04:02 PM
bbtkd's Avatar
bbtkd
bbtkd is offline
A guy has a 67 Ranchero listed on Ebay right now and he has done exactly what you are asking about. He apparently transplanted all of the electronics. You may want to contact him for particulars. You can get a message to him through ebay. Go to the link below, then click on his Ebay ID to send him a message. Good luck.
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=592227871
Tom
Old 01-27-2002, 12:33 AM
MGT351's Avatar
MGT351
MGT351 is offline
You will need the computer from the donar car to make the EFI work right, unless you already have the 86 motor, I would recommend going with a 87-93 Mustang setup, they use bigger Throttle bodies, better heads and larger injectors. The cpu in a 86-88 will also be speed density, unless it is a 88 model california car. 89 (88 cal)-93 are mass air. If you plan to run a bigger camshaft you will want the mass air. Mass air vehicles can adjust to changes brought on by cams, better breathing heads and so on. You will want to get all the sensors from the donar car as well as Oxygen sensors (mustangs used 2)
If you have any questions fill free to ask, I will try to answer as best I can
my address is : mam351(No Email Addresses In Posts!)
Old 05-24-2002, 05:55 PM
allwheel4x's Avatar
allwheel4x
allwheel4x is offline
:-staun I also have a 67 Ranchero,289,3speed,etc,stock.All it needs is a tailgate to be complete.Very little rust and fully restorable. Why would you want to put a FI engine in?Totally ruins it!
Old 05-27-2002, 02:32 PM
Supercab's Avatar
Supercab
Supercab is offline
LV2HNT
05-26-2012 11:06 AM
calgearhead
Engine Swaps
07-24-2004 10:04 AM
Copper93
1978 - 1996 Big Bronco
06-26-2004 10:11 AM
83shotbed4x4
02-16-2004 06:47 AM
laros
06-29-2001 11:02 PM
Quick Reply: Looking for help with fuel injected into my '67 Ranchero.
