Dealer says 6.0 is a 18qt. oil system???
I asked my dealer this morning if I came in for an oil change ,do they put 15 qts in or do they account for the 1-1.5 qts in the oil pump and put 13.5-14 qts in.. Dealer tells me system hold 18 qts. # qts stay in engine so they add 15..Is this BS or true story???
I'm not sure.....but I don't think the oil drains out of the high pressure oil pump, so only 15 quarts come out, so 15 quarts go back in. If it did drain out of the HPOP, it would take a long time to start after the change since the injectors run off of high oil pressure.
I'm almost certain that the injector oil does not follow the same path as the lube oil. It returns to the pan. The lube system, and hpop system are on different paths. Same Oil, same filter, just not the same linear system.
I hope that makes sense. I seemed to ramble on....Joe.
Originally Posted by GTPSteve
Sounds about right to me. most of the time I put in 15.5 to 16 Qt. After the change just check the dip stick. and see if the filter housing is clean.
My vote is for BS...
I'd ask them if they measure what comes out, I've never had 15 qts drain, like you stated, that's the capacity but it does not all drain. They are draining into a 55 gal drum most likely, not paying attention to how much comes out, so it's important to check the stick. And if you overfill these, it's easy to miss it because once it's past the white plastic tip (on mine anyway) it's hard to read a level.
Per the tech folder here, 13.5 is about right, I usually put in at most 14 quarts to get 3/4 up the hash marks on the dipstick on mine, but either way I think they are wrong on the 18 qt capacity and 15 qt fills. If you let them do it, just be sure you don't leave over-filled!
on
I always put like 12.5 to 13 qts in mine to get it to the bottom area of the dipstick, And I dont want any more than that. Too much oil for the 6.0 is bad news. These trucks running to much oil are probly the ones losing injectors, high pressure oil pumps, high pressure fuel pumps, oil leaks. ect, ect....
