North Carolina Chapter Join Chapter, Leader:Benztechnc
Cats?
Old 01-20-2007, 09:24 AM
ChevmaninaFord's Avatar
ChevmaninaFord
ChevmaninaFord is offline
Cats?
I talked to a muffler shop here in Greenville, NC and he said removing the back cats would trip the rear O2 sensor, what about the pre-cats??(I dont know what theyre called) Would removing these cause me to not pass inspection under the new laws?
Old 01-20-2007, 10:20 AM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
Yes if you remove them you will fail the inspection. I can't say about the location of the cats best I can say talk to someone who does inspections.
Old 01-20-2007, 10:40 AM
InstantGrits's Avatar
InstantGrits
InstantGrits is offline
The easiest thing to remember is if it was on the truck from factory it has to be there for NC OBD2 inspection.
Old 01-20-2007, 12:44 PM
ChevmaninaFord
Well thats no good, was Ford having trouble passing emissions because Chevy and Dodge only have one pair?
Old 01-20-2007, 12:55 PM
InstantGrits
Truth be known I only know from the inspectors side. Not sure why its done that way. Sorry man, I aint much help.
Old 01-20-2007, 01:14 PM
ncfirefighter46's Avatar
ncfirefighter46
ncfirefighter46 is offline
i have changed some on chuckyes (chevy) that had pre and aft. o2 sensors, and yes you will get a code if they are not there and the engine will run crappy, best thing to do on a 96 and newer is to buy the pefromer exhaust made for the o2 sensors, they do make them and high out put cats and do some mods and programming to the truck to get the high output if that is what you are looking for. if it is just changing the exhaust, then buy the kit mad to replace the factory a lot of compines offer them and they are not really that cheap but it is the right way to go and pass the OBD II
Old 01-20-2007, 01:55 PM
ChevmaninaFord
I've changed my exhaust enough, I was just trying to find out why the Fords were different, thanks for all the help. My Dynomax Bullet is pretty loud, I just wish it would idle louder.
Old 01-20-2007, 01:59 PM
ncfirefighter46
the before and after o2 is to make the engine run more cleaner, it gives more info to the computer to control the fuel air ratio: and if you wnat a louder exhuast you may be able to just change the muffler to a glass pack or just gut the muffler i have done that
Old 01-20-2007, 02:38 PM
ChevmaninaFord
The Dynomax Bullet is straight through, it does have ceramic insulation in it similar to a glasspack.
Bob at warsaw
04-05-2008 10:48 PM
one_wicked_element
Michigan Chapter
29
01-29-2008 05:58 PM
92F150Flare
South Carolina Chapter
06-02-2007 10:04 AM
autospecial
54
04-04-2007 08:55 AM
Quick Reply: Cats?
