disc brake conversion 1957__1964 F100
Received 1,353 Likes
on
http://www.fordtrucks.com/article/id...1964_F100.html
Related Articles
1967 - 1972 (with 1973 - 1976 Supplement) 4 X 4 F100 POWER STEERING CONVERSION
11-30-2004
Power Steering Pump Installation
8-2-2004
Brake Tech for early model Ford F-100 Pickup trucks through 1964
8-2-2004
1998 F250LD 5.4L V8 Outlaw Power Intake System Installation
12-8-2006
Related Articles
11-30-2004
8-2-2004
8-2-2004
12-8-2006
on
Obviously never driven a International?
I guess after tears of driven my 58 International Ford don't seem too bad to me. I guess if brakes are giving a problem on a truck very worth while to change.
I guess if I had a automatic it would be very worth while but with down shifting and coasting I guess I never had a problm.
on
on
1 Post
on
Originally Posted by Dustin1690
Very neat article lots of people do that these days switch to discs. I agree if the drums still work good and can stop I dont see the point but I guess for safety reliability
It`s the older trucks that need a much better brake system (disc or drum), especially if a more powerful engine is installed. It`s too easy to drive faster and harder then what the brakes are capable of handling.
on
1 Post
Originally Posted by Fomoko1
On anything newer than about 65/67 the stock drum brakes are fairly adequate unless doing alot of towing.
on
Found that the pad had frozen to the disc and when i went to back up the pad sheared off from the rivets and fell on the ground. I stepped on the brake and the piston went out further.....pedal went to the floor.....I said what the %$#@$#.
Hortons reembursed me $26 for the $65 NAPA pads.
There was no fluid loss and now if i have the same problem NAPA is right here and Kelly says i have full warranty.
I think it is because there is no shield and snow piled into the back side of the rim.
IDIoit
08-15-2016 09:10 AM
Madrid1214
07-21-2015 12:52 PM
robbyriot
03-27-2015 12:56 PM
DasFord
19
02-18-2014 10:33 AM
