Frustrated with my v10 help!!!!
Let me start out by saying thanms for having me at this forum. Ok i have a 1997 e350 work horse with the 6.8. This is my first ford so i do not know a whe lot about them. I purchased this at a reasonable price because it ran like crap. I pulled codes it had 4 plugs missing and lean bank 1 and 2. I put all new plugs in. With boots. Did tests on all cop and they all tested good.also i replaced the egr computer part. That was also a code it pulled. Cleared codes and it runs but not well has a major hesitation and smells like a gas factory out the tail pipe. Running way rich. And is not as responsive as it should be. No codes are present now. Please help. I love this van!
Check the IAC valve and the TPS sensor.
Check for vacuum leaks, particularly the PCV line.
I am going to change the vaccum lines they are bad looking but couldnt really find a definate vaccum leak i did however notice the dpfe vaccum hose is actually pushing air not a vaccum thos may be a problem. I am going to test the tps and iac like you said. Not sure about the cat conv. I do appreciate the help thanks
It's interesting that it had lean codes, but it sounds like you did nothing to fix a lean condition.
Check for vacuum leaks - one thing that can make it run rich is the fuel pressure regulator not getting vacuum which makes it set the pressure to 38-40 psi which is too high for idle.
At idle, the fuel pressure regulator should get full manifold vacuum. Check there first. I'd also check the fuel pressure at idle, it should be 28-30 lbs.
Clogged cats will first start affecting high speed or heavy load conditions, not allowing the engine to get up to full power. The max speed starts to drop. For example, a hill you used to be able to go up at 70 mph now it will only do 60 mph, then 55 mph, etc. Eventually it will only be able to do 35 mph on level ground. A cat with a broken up ceramic will get you to the 35 mph limit right away. The engine will rev and idle fine, but have a massive loss of power. During the early stages you can even get up to 65 mph if you do it slowly, but there will be noticeable loss of power when accelerating hard. There are exhaust pressure testers available (ebay $30) that plug into an O2 port.
i changed pcv valve, tps, cleaned iac, disconnected exhaust at cat conv. Now when i start it runs good for about 2 min then starts missing intermitently then constant. Wondering if injector bad? Or is a coil shorting? Still no codes when i scan it.??????
Two things I can think of that change when the engine gets hot.
First, the engine coolant temp sensor for the PCM will show a higher temp.
But, if the sensor is bad and the PCM reads an incorrect temp when the engine is hot that is probably an issue.
Try finding out what temp the PCM sees when the engine is hot.
The 2nd is the PCM switches from open loop to closed loop control.
Not exactly sure what that is, yet.
It involves the O2 sensors and cats.
I think the O2 sensors have heaters to get the change over to happen quicker.
There are articles I've seen with Google searches discussing it.
yes o2 sensors are hooked up i have the exhaust disconnected at y pipe and cat. So i can hear the motor better the miss seems like one cylinder to me. And i am getting no codes. That is why i thought maybe a coil break down. It also still has a hesitation at acceleration. I umderstand about coolant temp sensor but would that throw a code? Suprised about no codes. When i got the van it would barely pull itself its alot better just hate the miss.
