Bed on an 05 Chevy
its probably that the frame is twisted on it somehow. go look at teh truth about trucks video you might be susprised and maybe it can answer some of those questions for you. that is kinda rough to say it like that but its the truth. the frames on those chebbie half tons are just weak so i suppose they would be more prone to twisting and bending. maybe someone who had it before you went over a speed bump too fast or something
They can't be that bad. I think it was just an alignment problem. All the 4 door Chevy's I have looked at since are misaligned amost identically. I need to mention that I only notice it on 4x4 2500 4 doors.
Off-Road magazine did just mention in an article that the frames are getting stronger and have been problamatic on all trucks in the recent past.
It's really simple. This applies for any frame, on or offroad vehicles, equipment etc. Due to the flexing, and stresses put on the frames, vertical welds are more prone to cracking, and buckling under load. There is nothing wrong with mounting objects on the frame throughwelding, but it's a good idea to keep it to a minmum, and parallel with the frame. What we're talking about is completely different since pieces of the frame are being joined. It doesn't matter how good the quality of welding is, the fact is vertical welding on frames is NOT a good idea.
Originally Posted by duramaximizer
Look at about any mounts on a frame, they are all weld....and yes, a lot are vertical. Why is vertical welding bad? Robots weld these thing, not human. Right?
(As I scratch my head....)
im sure the reason the frames are so weak is to save themselves some bucks. im sure it isnt cheap to build a strong frame such as fords so if they put a cheap one on people are still going to buy it. no matter how crappy and unsafe it is just because there is a bowtie on it. supposedly gm did put a 200% stronger frame on their 900's. still aint as strong as the f150's several year old design haha.
HA HA! I would be willing to bet MONEY that if you laid any of the big 3's BARE half ton truck frames from any previous generation truck side by side 90% of you guys wouldn't be able to tell one from another. You guys' can believe that goofy "truith about trucks" video if you want. But the ONLY reason ford has gone to a boxed frame is they hope to sell more trucks by attempting to make the F-150 drive and handle more like a unibody car through building a stiffer chassis.
C channel frames worked flawlessly for almost 100 years IN FORDS as well as all other mfgs But now all of a sudden a C chanel is cheap and dangeous, I got news for ya loads ain't got any heavier than they were a few years ago and I've only seen 2 broken frames one on a 77 Ford and the other on a 75 Chevy
The ford cracked right above the rear axle and the chevy cracked right behind the cab. Both cases involved SERIOUS abuse and misuse.
