"59 - f100 - 292 firing order
started after 13 yr. storage. it ran well for first couple of days. then began missing with loss of power.cleaned fuel system, replaced oil&filter,points,plugs & wires and found bent p/rod - corrected. starts easy but when running there is no power and has wet ride side exhaust pipe with little smoking(dual exhaust). when pulling each plug wire it seems the end cylinders cause engine to slow but not when pulling the inside plug wires.
could it have jumped time? any help is appreciated 'cause i'm stumpped in the back yard.
straight6fl
05-02-2020 03:27 PM
ExPACamper
35
01-13-2018 11:37 PM
justaworktruck
10-14-2016 04:20 PM
Rusty_S
01-26-2016 09:59 PM
