Looking for a Bio-Diesel Partner
I've been doing a lot of reading and asking a lot of questions and am now interested in setting up a small Bio-Diesel production operation. Nothing large, mind you, just a small 35-gallon-per-batch setup. Should be able to produce enough to keep a couple of trucks supplied with all the fuel they'll need by putting in a few hours a month worth of effort.
Trouble is, although I now understand how to make it, and can afford the investment to buy the equipment, I don't have anyplace to set it up. So, I'm looking for a partner. You supply the space, I'll supply the equipment, and we can split the cost of supplies and the waste oil gathering duties.
Only "catch" is you have to be close by enough that it isn't too much of a hassle for me to swing by for fill-ups. I live in Kent and work in Sout Seattle. Anybody around here in the South Seattle, Kent, Fife, Milton, Tukwila, area who would be interested? Send me a PM if you're interested....
I've been asking a lot of questions and have recieved a lot of good answers from the folks in this forum. Now I think I'm about ready to set up a small Bio-Diesel production operation. Nothing large, mind you, just a 35(maybe 50)-gallon-per-batch appleseed setup with methanol recovery and magnesol cleaning. Should be able to produce enough to keep a couple of trucks supplied with all the fuel they'll need by putting in a few hours a month worth of effort.
Trouble is, although I now the info I need now, and can afford the investment to buy the equipment, I don't have anyplace to set it up. So, I'm looking for a partner. You supply the space, I'll supply the equipment, and we can split the cost of supplies and the waste oil gathering duties.
Only "catch" is you have to be close by enough that it isn't too much of a hassle for me to swing by for fill-ups. I live in Kent and work in South Seattle. Anybody around here in the South Seattle, Kent, Fife, Milton, Tukwila, area who would be interested? Send me a PM if you're interested....
Originally Posted by Bioford
I have been making biodiesel for awhile now and would be happy to answer any questions. Also why not make bigger batches? When you invest so much time per batch,depending on the process you are using, it is nice to have a larger outcome like 100+ gallons.
Three 35-gallon batches a month would be more than enough for my needs. I might go with a 50-gallon-per-batch reactor to cut it to two batches per month, but I really can't see the need for anything bigger than that.
The problem with processing bigger batches is it means needing more storage for finished product as well as more storage for WVO. That means more space, and space is what I don't have...
good point. the first processor i made produced 30 gallon batches in around 23 hours though operator time was only around 1-2 hours. I needed more fuel per batch to justify the time and effort. I also shared some with friends. I just threw that out for consideration, personally I ended up building a larger processor very shorty after the construction of the first one.
Naturally if I built a 35 or 50 gallon appleseed processor and the throughput was insufficient, it would be pretty easy to build another one right beside it. Of course the second one would cost less than the first because they could share some of the equipment (pumps, valves, piping, etc.).
I am thinking of incorporating some of Fabman's ideas into my setup. Like a vacuum recovery still for cleaning the methanol out of the bio and magnesol for drying it. None of that would need to be duplicated either, and will greatly reduce the overall batch time as well, right?
Isn't most of that 23 hours per batch you mentioned the time spent cleaning and drying the processed bio? The actual reaction time is only a fraction of that as I understand it.
