97 ford f 350 Powerstroke, Won't Start
I acquired this truck two years ago and it worked great with the exception that on one occasion i went to start it, it turned on then shut down. I waited for 30 minutes before it started back up. On a second occasion i was driving when it suddenly just died. I again waited about 45 minutes when it started up again. Now again it started up then turned off and I haven't been able to start it up in the last two days. I have noticed that when it hasn't wanted to start the "wait""water in fuel" light cluster does not come on when I turn on the ignition. All the other instrumentation comes on with the exception of these. Anyone have this experience or can shed some light?
Thanks
Rick
97 Ford F350 7.3 Powerstroke, Automatic
Thanks
Rick
Give us more information on what it is doing when it won't start so maybe we can help: Is the tach registering when you crank it? (If not, then you have CPS problems) Are you getting any smoke? If so what color? Is it spinning over fast when you crank it? etc. The more information that you can give, the better it will be for poeple here to help you.
It has about 200rpms when i crank, it has no smoke coming out when i crank it, it is spinning over normal when i crank it. it rough idled when i started it last then it died, i tried to restart and it almost started. then after that the wts light and the water in fuel light wouldn't come on and now it just cranks normally but won't start. Temperature was in the mid 70s.
Checked all the fuses they are fine. Did need some oil so I filled it up but do not know what the HPOP is. Now that i crank it though my "water in fuel" "fuel filter" lights come on when i crank it where they didn't used to before. The only light now that does not come on is the "Wait to Start".
Well Folks, She's up and running. I was about to take the pcm off but decided to hook it up to the battery charger. I set it on start and the wait to start light came on and she started right up. I cleaned the battery terminals on both batteries and am charging them. Thanks for all your help as for I have gained valuable information.
Powerstroke1995
16
11-02-2012 12:55 PM
F350Scott
18
05-12-2009 10:59 AM
