1999 F150XLt anti-theft light blinking
Old 01-06-2007, 06:56 PM
larana's Avatar
larana
larana is offline
Our truck is intermittently not starting. The ignition turns but doesn't catch. When it does start the anti-theft light blinks seven times and continues to do so. I switched to the spare key but the problem still is ongoing. any help would be appreciated.
Old 01-06-2007, 07:49 PM
macjb's Avatar
macjb
macjb is offline
Does the engine turn over, but not start when you have this problem? I have the same thing going on. I have tried switching keys and it doesn't seem to help. I have noticed it does it when I lock/unlock the truck several time without actually starting the truck. When I'm at work I will run to my truck and get something out of it and lock it back.
What works for me is to close the door, use the remote lock button and lock, unlock, lock, unlock, lock, and unlock and it will start. Sounds stupid, I know but it has worked three time for me.
Try this and see if it works. I hope this helps.
Josh
Old 01-06-2007, 08:32 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
When failure occurrs, leave the ignition in Run for several minutes and wait to see if the lite flashes a 2 digit code.
If so come back and tell what it is.
I can give you a lead on what the system sees as a fault.
Old 01-07-2007, 10:34 PM
larana's Avatar
larana
larana is offline
anti-theft light code
Well if the blinking of the anti-theft light is in code then I would say it is the number 16. this truck doesn't have a remote alarm/entry. i am just wondering if it is an electrical problem or mechanical. thanks.
Old 01-08-2007, 02:02 PM
Bluegrass 7
There is no code 16 listed. Check again carefully what the two digets are.
They should repeat.
EXAMPLE: 2 flashes -space- 4 flashes would = a code 24.
rickebowdle
1999 to 2016 Super Duty
16
09-21-2021 07:11 PM
TexasRebel
12-28-2010 07:11 AM
RobbyMartin
1997 - 2003 F150
12-18-2009 10:23 PM
HogTied
1997 - 2003 F150
07-13-2007 05:46 PM
bobsevern
1983 - 2012 Ranger & B-Series
03-14-2004 04:07 PM
Quick Reply: 1999 F150XLt anti-theft light blinking
